01-16-2006, 11:44 PM | #1 |
'Burban Legend
Of High Humps and Low Humps
Can someone give me the Cliffs Notes version of the difference in high and low hump floors (other than the OBVIOUS) I am converting an A/C cab to a standard dash for a friend on the board, and I want to make sure I am getting him the right set-up for his application. The cab was originally A/C, with clutch pedals. It has no VIN tag and no GB door, so I don't know for sure what exact configuration it was. The floor has been buggered up some in the hump area (the lip was removed), which I will be fixing, but I want to make sure HIS '70 Chevy 4X4 hump will mate up in the end. He lives an hour+ away, or I would just take his out and try it. Can anybody give me an idea what is correct. I have a new lip and hump that fits, from a 2WD, 4-speed donor truck, but I want to make sure the 4X4 is the same before I get TOO far. Thanks, Mike
'67 Chevy Iron City Beer Truck (9ft step) '67 Chevy Panel Truck 467 '68 Short Fleet 305v6 '68 McLaren Ramp Truck '68/'68/'70/'71 Burbs 292/366/402/454 '69 C-30 dump '71 C-50 dump and church bus '71 4x4 454 '72 Blazer (w/pop-up camper) $15 x-hooks '66 Chevy II 194/Weber '68 El Camino" 305v6 '69 Skylark 455 Buick '70 Chevelle 427 '71 Cutlass W-31 '71 GTO 400 2x2 "The 51" Chopped '51 Chevy (409) my first car OK Toad, we'll take 'em all... John Milner |
01-17-2006, 12:04 AM | #2 |
"Ochre Ogre"
Re: Of High Humps and Low Humps
It's the same just with an additional T-case hole and the 4spd hole is a couple inches further back.
As far as the cliff notes, the only humps that are bolted in are the high humps. Low humps are part of the floor pan and not removable without some sort of cutting device. Cut it out and add the high hump and you are set.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 Last edited by da-burb; 01-17-2006 at 12:08 AM. |
01-17-2006, 12:26 PM | #3 |
'Burban Legend
EXCELLENT! Thank you DB. So here is what I'm hearing: All 4-speed trucks are high humps. ALL 4x4s are high humps (auto OR manual). All column auto and 3-on-trees are LOW humps, which if you cut out the hole and drill the bolt holes, a high hump will bolt right to a low hump cab. Did I miss anything?
01-17-2006, 12:56 PM | #4 |
I think all that info is correct. To make the job a little easier (for future removal/instalation) some people will bolt it together and put a tack weld on the nuts to the underside of the cab floor. If the truck started out with a factory high hump cab it will already have square nuts welded to the underside of the floor.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
01-17-2006, 02:59 PM | #5 | |
Questionable
http://satellitehead.com/gallery/thu...album=9&page=5 On the low hump floor, you'll see a little dimple all the way around the floor area - it lines up pretty well perfect with the high hump it's like an outline of where you should cut. Use a jigsaw with a really good finetooth blade and go slow to cut the old one out. Even though the line is there, be sure to measure up b4 cutting anyway!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
01-17-2006, 04:40 PM | #6 |
'Burban Legend
Neck: I was thinking of splicing the whole section in with the factory nuts and all, but that might not be a bad idea what you suggested about tacking the nuts. I will have to get Chuck (Chucks70) up here to see what he would prefer. Thanks.
Shifty: I will have to check out your link when I get back from my sons basketball game. It sounds like you have taken some good notes for us all to share. Thanks to you as well.
01-17-2006, 09:13 PM | #7 |
Add to the high hump-BB autos 2wd.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
01-17-2006, 09:55 PM | #8 |
its all about the +6 inches
all 4 speeds
all 4X4 big block w/ auto GMC 1/2 ton 305 V-6/TH400 All these would be high hump. |
01-17-2006, 11:52 PM | #9 |
I think you have the high hump application correct. It seems to me I saw a diagram and explaination in an LMC catalog. Can't find it now though. The low hump will fit over a BB w/TH400. Pretty close but it does work. I put one in my '69 GMC swb.
01-18-2006, 12:03 AM | #10 |
'Burban Legend
Thanks Dave and Andy. I'm curious as to what would cause the need for a high hump with an auto. My factory BB truck was converted to a TH400 from a 3-on-tree and can't see any mods to the hump area. Was it for clearance purposes for the motor being further aft? If so, it doesn't appear to have been an issue with mine. I'm sure GM had their reasons. Thanks again, Mike
