Sway Bars with air bags?????????
![]() ![]() Last edited by bskylerj; 01-17-2006 at 01:14 AM. |
Happy to be here
![]() Join Date: Mar 2000
Re: Sway Bars with air bags?????????
We bagged my 77 Cheyenne and it rode and handled just fine. I have "heard" the same thing, so I had a front sway bar installed while the new motor was being put in. I haven't driven it yet so I don't have any input yet.
Blank
Sway bars make a world of difference. As long as your air bags work evenly you will have no trouble. For example if you have your fronts on different lines and you can lower one side before the other you could bend the bar to the point of breaking.
![]() 1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi. 1977 Corvette 350-375hp 4speed, silver show car. 2002 S10 xtreme, work truck 2004.5 VW jetta GLI 1.8T 6speed, weekend warrior. 2013 Audi A3 TDI, the wife's car |
Come on fellows, I know more of you have airbags than just these 2. I would love more input. Thanks
Happy to be here
I'll move this to the suspension so maybe it will get more response...
thanks
#7 | |
I have had both with and without sway bar. In my opinion it can't hurt to have the sway bar. The biggest thing is to run your bags independent to each other. If you run them combined then you will get transfer between the two bags when you turn. Alot of it too is the install of the airbag itself. I have a 2000 silverado that was bagged when I bought it and it handled like ****. I basically rebagged it making new mounts and what not. With that all done it is night and day before and after. I would also suggest running the "slam specialties" bags in the front of any fullsize that you bag. These make a huge differance from the 2600 firestones most people use.
Active Member
Are the Slam Bags also 2600# ? What seems to make them work better ?I've got a front bar and seperate lines to all 4 corners and would change them if it was worthwhile.
Here are some links to answer some of your questions. The one I can answer for you is YES it is worth switching!!
http://www.slamspecialties.com/ http://www.gravity-werx.com/index.as...TS&Category=12 |
Formerly ADHDCARGUY
I have front and rear sway bars on my lowered '67 SWB with rear bags. It handles great and stays flat in the curves! I love those freeway on and off ramps and twisty roads.
Jay 67CHEVY SWB,355, built 700r, 5/7,9",posi 3.50,REAR BAGS,HOOSIERS, A/C. 54CHEVY - BURB, beginning construction(well, i gotta take it apart first!) 36FORD PU - WAITING 38CHEVY - 2DR SD,CHASSIS FINISHED 46CHEVY - BURB - waiting |
