Old 01-17-2006, 03:08 PM   #1
72str8flush
72str8flush's Avatar
Steering Question
OK so I think I need the help of some of you guys. My steering was off when I bought my truck, aligned wrong and generally sloppy. I felt that my adjuster sleeves and outer tie rods needed replaced, so I did that.
Then I took it into the shop to have it aligned to see if that fixed my problem. They told me that I needed all ball joints and A-Arm Bushings replaced? How can I tell if that is true? It is still kinda sloppy, although not as bad, and gets a little squirelly at times.
Any help will be appreciated, because I am afraid that the shop was trying to screw me (even though I could do the work myself and then have it aligned, that's not something I want to get into if I don't have to). They said some sketchy things, so I need to double check.
72 Chevy Short Bed Fleet: 350/TH350 - Sold - Now trying to sell the parts that I have left over.
_______________________
2006 VW GTI
72str8flush is offline   Reply With Quote
Old 01-17-2006, 03:15 PM   #2
gentry69
gentry69's Avatar
Re: Steering Question
ball joints arent that expencive so if u can do them your self i would as far alligning it i did mine my self to if your balljoints are loose an wore out that might be causing your sloppy steering
gentry69 is offline   Reply With Quote
Old 01-17-2006, 03:17 PM   #3
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
I'm not suprised you need ball joints and bushings. You should be able to see the bushings, or lack there of, from the top of the A-arm. to check ball joints jack up the front tire, and try to jiggle the wheel.
If you drive your truck for long with sloppy steering you can chew up a lot of parts.
I like urethane bushings better than rubber when it comes to longevity. They will stiffen things up a bit, and there is a lubrication issue, but well worth it.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 01-18-2006, 01:10 AM   #4
72K10
Most accurate way to determine reason for "slop" is to have someone move steering wheel while you're under the vehicle. Might find a worn pitman arm or other link. Not sure how ball joints would affect steering.
Chris
RLTW
70C10
72K10
72K10 Cheyenne
72C10 Cheyenne Super
72K10 is offline   Reply With Quote
