Old 01-17-2006, 08:36 PM   #1
RAB38
Steering box bracing
I just installed a cross over steering system on my 72 blazer, I have a tremendous amount for frame flex when I steer the truck. They do not make steering box braces for the first gens or at least I have not seen any. I am looking for suggestion on how to fix this problem before it breaks the frame.
I was thinking that by welding in another cross brace from one frame side to the other near the steering box would help but I don't know if it is enough.
RAB38 is offline   Reply With Quote
Old 01-17-2006, 08:54 PM   #2
tnblazerk5
User #12137
tnblazerk5's Avatar
Re: Steering box bracing
yes they came from the factory on sum blazers and jimmys and there is sum after market one also but been a while since i seen them
also check and see if the rivits are loose in the frame around the box if they are take them put and put bolts back in there place
look at the ones for 73 up ones and make one like it for your
tnblazerk5 is offline   Reply With Quote
Old 01-17-2006, 09:17 PM   #3
mkmiller1
mkmiller1's Avatar
Welcome to the board!
factory braces came on the 71 and 72 model blazers.
Matthew
GOD is good...All the time!
'71 swb custom10 barn find-68K original miles
72 K5 CST rust bucket, but runs and drives 84K miles
mkmiller1 is offline   Reply With Quote
Old 01-17-2006, 10:39 PM   #4
RAB38
I believe the brace you are refering to is the additional plate that fits in the frame where the box mounts. What I am talking about is a brace that ties the frame where the box mounts to either the engine crossmember or the other side of the frame.
I checked my frame and the rivits are fine and there are no cracks and the reinforcing plate is in tact.
Old 01-18-2006, 12:02 AM   #5
jhow66
jhow66's Avatar
Try this: --my son (orangeuavol) did his Blazer this way-so far so good.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-18-2006, 04:15 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
If you can find one, this is the factory steering brace
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-19-2006, 07:47 AM   #7
vtblazer
vtblazer's Avatar
I read/heard somewhere that the bigger problem is the 'travel' of the factory boxes.
From the factory, they will want to travel (turn) farther than the lockout on the steering system will allow, so @ lockout you are still getting all the forces of the hydraulics trying to push, that's what breaks the frame.
Fixing the travel of the steering box first will prevent that issue.
if your frame is flexing during normal left/right steering motion than disregard all above, 'cause you have other concerns happening there.
vtblazer is offline   Reply With Quote
