Old 01-17-2006, 10:27 PM   #1
muddyole 69
Kinda Weird Find ........need info
Cruisin home after another wonderful 12 hr night shift and spotted this yellow truck nose peeking out from the side of a shed so I stopped and talked to the owner he is an older fellow and said I could have the truck after his boys pull the water well drilling rig off the back just to get it out of his yard good price, but I saw something odd the rear diff is a wide five bolt pattern looks like the type typically found under the larger trucks of the 50's and 60's I have a similar rear under a 67 F600 dump was curious if this could be an odd factory rear or if someone just swapped a heavier rear for the massive rig on the back. The truck is 157 inch wheelbase and frame is in great shape cab is fair for around here and front clip is 68 that is teee-rashed !!! any info is greatly appreciated Mike
hav'n fun be'n me
muddyole 69 is offline   Reply With Quote
Old 01-17-2006, 10:53 PM   #2
Aquivarious
Aquivarious's Avatar
Re: Kinda Weird Find ........need info
WEIRD!... and thats all i have to say about that...
'71 Chevy C-10 SWB (Project)
'04 Mazda RX-8 (F*** around Car)
'85 Chevy C-20 (Former Project)
Currently Serving In IRAQ. (Man it sucks over here..)
Aquivarious is offline   Reply With Quote
Old 01-17-2006, 10:56 PM   #3
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Pics needed! Is it a C30?
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 01-17-2006, 11:05 PM   #4
muddyole 69
yea its got the badges saying one ton unfortunately I did not have a camera with me and I really do not want to push the guy with it being a freebie I can wait just wanted to see if anyone else ever saw this Mike
hav'n fun be'n me
Old 01-17-2006, 11:36 PM   #5
Bob Moore
Yes but I don't know what year or what size. Some of the newer and larger Step Vans like the city utilities use have a large diameter 10 bolt wheel. IIR the front uses all 10 and the rear only 5. The wheels are dually style and can be used front or back.
Hope this helps a little - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 01-17-2006, 11:49 PM   #6
Geezer
Geezer's Avatar
Might be military truck wheels and rearend. Do they look like the ones on this page? http://www.garbee.net/~cabell/photos5.htm
If you can't drive it park it! If you can't park it milk it!
Geezer is offline   Reply With Quote
Old 01-18-2006, 12:47 AM   #7
409biscayne
409biscayne's Avatar
i looked at buying a c50 this summer and i'm sure it had a wide 5 pattern on the rear . so 2 and 2 1/2 ton may use that set-up . ( i think ) . good luck.
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
Old 01-18-2006, 01:15 AM   #8
muddyole 69
Thanks Guys the wheels are dual but the pattern looks close to the powerwagon I am with 409 figure its a heavier truck rear someone has swapped in Mike
hav'n fun be'n me
Old 01-18-2006, 02:16 AM   #9
tnblazerk5
User #12137
tnblazerk5's Avatar
i am going to say its a ho110 rear the same thats under my 1 ton truck
10 lug nut rear and 5 lug nut front
did the rear look like this
and the front look like this
tnblazerk5 is offline   Reply With Quote
Old 01-18-2006, 02:24 AM   #10
longhorn71
longhorn71's Avatar
most of the 67-72 one tons here have 18" rims under them here
longhorn71 is offline   Reply With Quote
Old 01-18-2006, 03:16 AM   #11
muddyole 69
TNBLAZERK5 I am 100% sure this truck had the wide five lug rear and eight lug front that is what had me wondering what was up thanks for the pics the front is the same as on the rear of this truck only a pair of duals .
Dean the truck supposedly is a factory cab and chassis truck no idea about longhorns thats why i am asking as I am not really sure what this thing is thanks for your reply will post pics after I get it home Mike
hav'n fun be'n me
Old 01-18-2006, 04:26 AM   #12
Bob B.
Sounds to me like someone swapped rear axles at some point. I don't think G.M. ever built a truck with 8 lugs on the front axle and 5 on the rear. Many 1.5 tons had 5 in front and 10 in the rear up until 2002, like the above pictures, but they did use the same wheels all the way around.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 01-18-2006, 04:33 AM   #13
muddyole 69
Hey Bob is it possible to run just 5 out of the ten lugs on the rear and leave the others out ? Cause it did appear to have holes between the five lugs come to think of it ! doh !!!! would've been helpful to mention that before hunh ?? But that still doesn't explain the 8 lug front unless this truly is a 68 and they swapped to a later front susp to get disc brakes maybe ?
hav'n fun be'n me
Old 01-18-2006, 10:17 AM   #14
IH and Ford used wide-5 lug patterns on their 1ton trucks well into the 60s.It`s probably one of those.They would have similar yoke and spring dimensions and came with 1ton wheel sizes.
