Old 01-18-2006, 01:49 AM   #1
72 GMC K1500
72 GMC K1500's Avatar
Question How do you tell if a Brake Combination Valve is Defective?
Can anyone tell me how you can diagnose a combination valve? I have replaced almost ALL of the front and rear brake components on my truck but the brakes are still terrible! I get very little nose dive on the truck when the brakes are applied with a lot of pressure and my only thought was that the metering valve component of the valve may be defective. Any thoughts?
1972 GMC K1500, sbc 350, turbo 350
Castle Rock, CO
72 GMC K1500 is offline   Reply With Quote
Old 01-18-2006, 02:19 AM   #2
71/454
Turbo Guy
71/454's Avatar
Re: How do you tell if a Brake Combination Valve is Defective?
Just my 2 cents but, I had an 81 do this same thing, you practically had to stand on the pedal to make it work. I went thru and changed a bunch of stuff and ended up living with it. I sold the truck to a friend who drove it into the ground and never cared to fix anything. I ended up buying it back a year or two later and as soon as I drove it I knew it needed a booster. I guess it was just slowly on it's way out when I had it and he could have cared less. When I was trying to diagnose it, it still held vacum if u pulled off the hose and the pedal sunk when u started it. I guess I'm trying to say maybe it's the booster, you never can tell seems like!
71/454 is offline   Reply With Quote
Old 01-18-2006, 02:25 AM   #3
avejoe
Custer had a plan too.
avejoe's Avatar
Been there, done that.
Replace your booster with a dual diaphram booster. It'll put you through the windshield.
72 K15 GMC (aka Big White)
Performance Rockers, Cab Corners, and Floors
Fossil Fuel Glutton
Neighborhood Nuisance
98 BMW 540i for Speed (Sold )
05 Subaru Outback for mileage
avejoe is offline   Reply With Quote
Old 01-18-2006, 02:28 AM   #4
72 GMC K1500
Thanks. I have not yet replaced the booster. Like you mention, mine does hold vacuum and I stopped looking there. Do you know how to test a booster other than checking for leaks at the hose and fitting?
Castle Rock, CO
Old 01-18-2006, 02:46 AM   #5
71/454
Turbo Guy
71/454's Avatar
Like i said it didn't work for me but u might as well try it. Sit in the truck with the engine off apply the brake fairly firm and then start the truck, if it is working properly the pedal should drop when the engine starts. I'm not sure this is an official troubleshooting method, I learned it as one of those "grandfather" teachings in a shop I used to work at.
Old 01-18-2006, 08:13 AM   #6
72 longhorn BB
72 longhorn BB's Avatar
I just googled your symptom, and found this link:
http://autorepair.about.com/cs/troub...g/a/bl302a.htm
hope this helps
Chuck
1972 C-20 Longhorn
402 BB .030" over (409?), curved HEI,
RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit
1999 K1500 Suburban (old style)
5.7L Vortec
4L60E
"No matter where you go, ........ there you are"
72 longhorn BB is offline   Reply With Quote
Old 01-18-2006, 10:26 AM   #7
72 GMC K1500
Will the rest of my brake components work with a dual-diaphram booster? Or will I have to replace (again) the Master Cylinder? Is the dual-diaphram booster a 3/4 ton unit, or for a later year truck? The reason I am asking is when I go to NAPA I just want to ask for the correct part. Thanks.
Castle Rock, CO
Old 01-18-2006, 11:31 AM   #8
avejoe
avejoe's Avatar
You will need to make sure the MC is designed to work with the new booster. The push rods can be of different length.
Fossil Fuel Glutton
