Old 01-18-2006, 02:38 AM   #1
71/454
Turbo Guy
71/454's Avatar
Woodgrain moulding fix?
I was wondering if anyone has heard of someone making new woodgain decal product. I was told by an older friend they used to make this to replace the peeling decal on the lower mouldings rather than replace the entire moulding, you could just buy it in a roll. I went to 3m today and the guy almost laughed out loud and said that they havent made it in years. But everyone else I talk to says it is still made. Any help?
71/454 is offline   Reply With Quote
Old 01-18-2006, 03:15 AM   #2
pjmoreland
pjmoreland's Avatar
Re: Woodgrain moulding fix?
It's listed in the LMC catalog:
http://www.lmctruck.com/icatalog/cb/0037.html
I have no idea what the quality is like.
pjmoreland is offline   Reply With Quote
Old 01-18-2006, 03:46 AM   #3
71/454
Turbo Guy
71/454's Avatar
yep thats it thanks very much!
Old 01-18-2006, 10:29 AM   #4
Available from many other sources as well.
Old 01-18-2006, 10:37 AM   #5
cstanley
cstanley's Avatar
i've also used the original GM product. it came in a roll about 14-18 inches tall, and was designed for the woodgrained sides on station wagons. i had to cut it into strips to fit, but it worked very well. i put it on about 10 years ago, and it still looks fine.
cstanley is offline   Reply With Quote
Old 01-18-2006, 11:34 AM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
3M made some called Dinoc. I have an old roll of it that was supposed to be used for a Ford, I believe. I haven't looked at the can, lately (like the past 10 years).
An old friend took some of the same product, and covered all of the window frame mouldings in his '51 Chevy 2-dr sedan. This was to replace the lost woodgraining that had been on them, when new. He used a heat gun to make the vinyl pliable, then formed it to the metal and it stuck like glue...which is what is on the back.
Member Nr. 2770
Old 01-18-2006, 12:27 PM   #7
Huck
Huck's Avatar
The original GM mouldings had a clear cover tape over the wood grain tape. It held up pretty good without yellowing but after 30+ years, it deserves to crap out a bit. You can get a wood grain style tape in most fabric or craft places. Not sure how well it will hold up but if it gives you a few years, it is probably worth it. Just need to get the right shade of wood. Biggest hassle is getting the trim off and back on without damaging the paint.
Huck is offline   Reply With Quote
Old 01-18-2006, 05:17 PM   #8
see ten
WTB this ad
see ten's Avatar
I used the woodgrain tape to freshen up my tailgate molding (which is a different height tape than the sides use). I think I got it from Chevy Duty.
see ten is offline   Reply With Quote
Old 01-18-2006, 10:32 PM   #9
6772fan
Active Member
6772fan's Avatar
See Ten- Your tailgate molding looks excellent. How did you fit it around the Chevrolet letters?
Lane
1979 Chevy SWB- (Second owner- Father in Law was first)
1979 Chevy Silverado SWB-Red/Red
6772fan is offline   Reply With Quote
Old 01-18-2006, 10:58 PM   #10
To answer for him.You remove the letters,apply the woodgrain,and reinstall the letters.
Old 01-18-2006, 11:10 PM   #11
Tim Christian
Tim Christian's Avatar
We carry it for the tailgate bands and the lower side molding.
Tim Christian is offline   Reply With Quote
Old 01-18-2006, 11:13 PM   #12
see ten
WTB this ad
see ten's Avatar
He is correct! And may I say it was a booger getting the adhesive off from the old decal. Take your time and you will be fine.
Old 01-18-2006, 11:32 PM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
And if your truck is more of a beater.... contact paper will do the trick!
Old 01-19-2006, 12:37 AM   #14
Striker169
Car O'Holic
Striker169's Avatar
How do you remove the letters on the back?
Striker169 is offline   Reply With Quote
Old 01-19-2006, 05:02 PM   #15
see ten
WTB this ad
see ten's Avatar
Mine is a reproduction piece that had little round clips pushed over the studs on the letters. I had to pull the clips off and flatten them back out for reuse. I used a small socket to press the clips back on to the studs. I don't know what kind of fasteners a OEM piece would have. Either way you will be taking the trim off the tailgate to fix it.
Old 01-19-2006, 07:37 PM   #16
powell72
powell72's Avatar
The OEM ones are riveted on! I ended up finding a better used one instead for my truck.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 01-19-2006, 10:28 PM   #17
6772fan
Active Member
6772fan's Avatar
Thanks for the info on the tailgate band. Since I have the OEM piece, guess I'll search for a better one. Take care.........
Lane
