Which A-arms will interchange with 72 truck?
I just found that one of my lower a-arms is bad. Does anyone know if any other a-arm from say a chevy truck or car is interchangable with that of a 72 chevy c-10 (2WD)?
72 Chevy C10 Custom Deluxe ![]() 03 Camary (Family Ride) 96 Jetta (piece of sh**) |
Re: Which A-arms will interchange with 72 truck?
From the help iv recieved from guys on this board....63-87 crossmember and a arms will work. If you go with the later style arms..you will automaticlly have a disc brake set up, a arms, crossmember, the whole 9 yards!!! I think they told me with the 73-87 crossmember, that you will have to elongate 2 of the bolt holes for it to bolt directly up....NO big deal. This is what i am planning on doing to my truck. I think it will be cheaper in the long run, and work exactly the way it should. Hope this helps.
I found the link to info that might help::: http://67-72chevytrucks.com/vboard/s...d.php?t=184458 **If i missguided this in anyway...someone please correct me!!!** A.Y.
-ADAM 2006 GMC Sierra 2500HD 4x4 Reg. Cab Long Bed LBZ Duramax Allison 6sp 1970 Chevy C/10 Short Bed Last edited by buildin72; 01-19-2006 at 03:41 PM. |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
He just has a lower "A" arm that went bad. The 71-72 are the only ones that are the same, however you can use anything from 63 to 72. The 63-70 would need a ball joint change and the steering bumpstop is a little larger so you can't turn as tight. The 71-72 of coarse are direct bolt and you would maintain your turning radiouse. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
![]() Join Date: Nov 2004
If you just want so switch out one A-arm you probably want to stick with a 71 or 72. The 67-69 trucks had drum brakes and the bump stop for the steering is different on the lower A-arms. You can use a 67-69 A-arm but you will need to grind down the "tit" on the spindle so that your wheels will turn as far as they need to (I used stock 67 lower A-arms with a stock 71 disk brake spindle and I had to grind the "tit" down so I could turn my wheel properly from lock to lock). I don't know about any other years. What I have listed is the extent of my experience. The upper arms are all exactly the same (67-72) except the 71 and 72 used a different sized ball joint.
Edit: You beat me to it Wes.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 01-19-2006 at 03:51 PM. |
#5 | |
I'm watching you!
Mike
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold ![]() |
#6 | |
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 01-19-2006 at 05:34 PM. |
#7 | |
I'm watching you!
Mine is messed up at the shaft. The hole is an oval, and all the threads are stripped out. Mine was off of a 71 rolling chassis I bought. Impossible to see while everything was together. Thats the only one I took apart today, but the others look to be in good shape.
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold ![]() Last edited by 68haywagon; 01-19-2006 at 05:53 PM. |
