01-19-2006, 02:41 PM | #1 |
Power brakes
My truck is a 1970 with 4-wheel drum brakes, non power. What is needed to convert to power? Booster, rod, brackets, MC. What else? Do I need to swap prop valves? Pedal? Is a drum booster different than a disc booster? And what do I need to look for to get the smaller diameter booster I've seen on some pickups?
I also found a 89 chevy van. Can anything be used from this to convert to disc?
I think the world needs a drink... Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster Last edited by sdkid; 01-19-2006 at 03:00 PM. |
01-19-2006, 05:29 PM | #2 |
Re: Power brakes
I bought a booster for a 73 chevy truck. $85.00 Then bought the bracket from
http://www.****************.com/ $150.00 Used the same proportion valve and worked great. Now I'm converting to disks mainly for the look and will be changing the master and proportioning valve. Night and day from manual to power even if you keep the drums all the way around |
01-20-2006, 03:23 PM | #3 |
Re: Power brakes
no change in splitter block needed unless you go to disc brakes in front then you would need a proportioning valve
01-20-2006, 04:10 PM | #4 |
Re: Power brakes
sorry not sure why that link did not show up. It is ****************.com
01-20-2006, 04:11 PM | #5 |
Re: Power brakes
ah maybe because he is a competitor with an advertiser or something. his name won't even show up . Weird!
01-20-2006, 04:35 PM | #6 |
Re: Power brakes
It will stay drum for now. Disc would be nice in the future though.
I think the world needs a drink... Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
01-21-2006, 01:08 AM | #7 |
Re: Power brakes
Wasn't there a thread somewhere on this board about someone using a 73+ brake booster on their 67-72 truck to get power brakes?
01-21-2006, 04:19 PM | #8 |
Msgt USAF Ret
Re: Power brakes
Here is one, I don't know if it's the one but it may be. If you click on the search button on the top of the page your post is on and type in a keyword or words like "power brakes" it should take you to some threads. V. V.
http://67-72chevytrucks.com/vboard/s...t=power+brakes
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. Last edited by VetteVet; 01-21-2006 at 04:19 PM. |
02-05-2006, 12:05 AM | #9 |
Re: Power brakes
here is my orig but they killed it--probably by mistake
http://67-72chevytrucks.com/vboard/s....php3?t=162730 |
02-05-2006, 04:13 PM | #10 |
Re: Power brakes
i resurected your original. http://67-72chevytrucks.com/vboard/s...d.php?t=162730
02-05-2006, 04:21 PM | #11 |
Re: Power brakes
thanks Ivscott-----sdkid, here is another pic. Remember if using stock pedal arm hole. from firewall mount to center of the booster rod hole is 8.5" Rod will allow for lengthening using split washers if needed. Hole may need enlarged on rod.
02-05-2006, 07:27 PM | #12 |
Re: Power brakes
i have the complete power brake setup off my suburban peddle and all disk front drum rear. Im doin an underdash setup on mine. All my stuff has been replaced except the proportioning valve but the brakes worked perfect. PM me for more info.....
