Old 01-19-2006, 06:15 PM   #1
raidermanny
raidermanny's Avatar
Electric fuel pump mounting
I have an electric fuel pump that I need to mount but the only place I can find for it to fit is on the outside frame rail just under the passenger seat between the 2 cab mounts. Would it be alright there if I drill holes and run most of the line on the inside frame rail? Also wondering where others have mounted thiers.
raidermanny is offline   Reply With Quote
Old 01-19-2006, 06:18 PM   #2
gangforward
Hootis is as Hootis does...
gangforward's Avatar
Re: Electric fuel pump mounting
Good question! Just a a new elec pump myself and have been looking at hmmm.... where do I put this darn thing. Still have the tank in the cab...
67 C10 LWB Fleet, 383, TH400, PS, 4BL-Holley, Headers & 3" Exhaust, 3" drop front, 4" rear springs, ECI shock relocate, Panhard Bar kit, wheels & tires
1995 Z28 Convertible - Borla, K&N, Lingenfelter Motor, C6 Wheels & Tires
1990 2500 4x4 Suburban 3" Catbac System, K&N, 2" Lift, Wheels, Tires
gangforward is offline   Reply With Quote
Old 01-19-2006, 07:02 PM   #3
raidermanny
My tank is in the bed up next to the cab but there still isn't a good spot for the pump
Old 01-19-2006, 08:44 PM   #4
kelsfine69
18 Till I Die
kelsfine69's Avatar
I put mine here.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 01-19-2006, 08:48 PM   #5
dwaite72lnghrn
I put mine on the inner fender and ran a 3/8 steel line between the brake booster bracket then behind the carb. I am trying to figure away to put a vacuum switch on it so it will shut off when the engine dies with the ignition on, In case of an accident I don't throw fuel all over.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 01-19-2006, 10:27 PM   #6
71Dragtruck
71Dragtruck's Avatar
You use a pressure switch on you oil pressure line, when the oil pressure drops off the pump shuts down. You can get this at Jegs or Summit, any performance or auto supply.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 01-20-2006, 03:51 AM   #7
raidermanny
I thought about putting it on the inner fender but the instructions say to put it as close to the tank as possible. I guess I'm gonna have to fab something up like kelsfine69. Does anyone have an opinion about mounting on the outside of the frame rail?
Old 01-20-2006, 06:17 AM   #8
dwaite72lnghrn
If you mount it outside the frame it will be hit by every stone, mud and road junk that the front tires throw back. 1 word of caution is if your pump only uses 1 line be sure to plug the return line or after every fuel fill it will syphon out the return onto the ground.
2009 HHR aqua blue
Dave & Jeanne
Old 01-20-2006, 08:13 AM   #9
jacobs
jacobs's Avatar
I mounted my Carter electric fuel pump on the outside of my frame 30 years ago, drove it 350,000 miles and it still works perfectly and have had no problems with dirt or rocks. I installed a check valve between the inlet and outlet so the electric pump isn't required to run 100% of the time.
jacobs is offline   Reply With Quote
