PROJECT 7DEUCE
![]() Join Date: Dec 2002
Need some quick starter help.....
When I got home from work I tried to start my blazer and the starter would not disengage from the fly wheel so I went down and bought a new silonoid and still have the same problem... The key cylinder still returns back to the start position but the starter still runs.... Any help would be great....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Re: Need some quick starter help.....
Sounds like the starter drive is a gonner,can you get it to release with the battery disconected?I would try that if you can then I would get anew starter.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
PROJECT 7DEUCE
As soon as I turn the key off the starter disengages????
PROJECT 7DEUCE
Ttt
C10 Club Tennessee
I'm having a similar problem. When I try to turn my truck over it attempts to start and then there is this AWFUL knocking noise. I took it up to my friends shop and he watched as I turned the truck over again. He yelled at me and told me to stop and said my starter was shaking. I got home and the two bolts are as tight as I can get them. I'm going to pull it off and check it from the top.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
![]() Join Date: May 2004
I had the same problem as Yellow69, went thru a few starters, cracked nose housings. When I pulled the engine, I found out what the problem was, a cracked & warped flexplate. It was cracked near where it bolts to the crank, so you can't see any cracks until the engine was separated from the tranny.
C10 Club Tennessee
OH PLEASE DON'T TELL ME THAT!!!!!!! I have the starter out, I just haven't had the money to go get the new one.
You could try spinning the flexplate by hand and see if you see anything that is obviously wrong with it. I did that with mine, but couldn't tell that it was warped until I removed it. I broke a 2 or 3 nosecones before I seen the problem. When I would engage the starter, the gear would hit the flexplate and make a god-awful noise and not turn the engine. Hope that's not the case with yours, maybe it just needs to be shimmed correctly...
Im gona go with the shimming option I wouldn't shim it to much because then you will shave the fly wheel teeth. Another thing to check when you are spinning your flywheel by hand is to see if the flexplat will move front to back. I have had the torque conveter bolts work themselves loose. That mey cause some starter problems.
C10 Club Tennessee
I've dropped the starter and there is no cracking of anything. It just started doing this about around Thanksgiving. I don't drive my truck in the winter, but i did attempt to start it the other day and it was still doing it. I'll check the flexplate. I've also had the bolts work themselves loose on my old 69. I'm going to go with a 700r4 in the next month or so. If that is the problem I'll have to wait until the surgery
