Old 01-19-2006, 09:40 PM   #1
russellmarling
russellmarling's Avatar
E-brake cable thing
I took out my e-brake cable and I seem to have lost the hanger thing that goes on the right front side of the frame and I can't remember what it looks like. Could someone post a pic of this part so maybe I can locate mine? If I can't find mine where can I get one?
russellmarling is offline   Reply With Quote
Old 01-19-2006, 09:53 PM   #2
dennislbrooks
dennislbrooks's Avatar
Re: E-brake cable thing
2wd--not sure about a 4wd
not crawling under the truck tonite but it is either 3/16' or 1/4" rod about 4" long total with a curly pigtail on one end and a sharp L on the other. Unless you mean someting else.
dennislbrooks is offline   Reply With Quote
Old 01-19-2006, 10:01 PM   #3
russellmarling
Yeah I think that is it. It mounts across from the end of the e-brake cable that comes out of the firewall. Where can I get one? thanks for your help.
Old 01-19-2006, 10:06 PM   #4
dennislbrooks
I am sure someone has one on the board---keep it toward the top until someone sees your post. One could be easily made --however it is probably case hardened to resist bending. Also easily done--after fabricating from rod, heat it red and dip in a bucket of water. Bending is over with at that point. Try ----- matt67350 if no one else close to you responds.
Old 02-06-2007, 12:21 AM   #5
JustLiveIt
JustLiveIt's Avatar
Found this thread after searching forever! I need this "pigtail" piece to hold my e-brake cable on the passenger side. I have the one on the driver side. Also I need the guide piece that is on the long rod from the passenger side. It looks like the e-brake cable equilizer in the picture below but is slotted to fit over the rod.
Hopefully somebody will have these! Thanks!
1968 Chev SWB Fleet with GMC Clip and lots of 71-72 parts!
JustLiveIt is offline   Reply With Quote
Old 02-06-2007, 01:40 PM   #6
meathead95
computer illiterate
meathead95's Avatar
i believe you can get all of this stuff from inline tube
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 02-06-2007, 02:32 PM   #7
JustLiveIt
JustLiveIt's Avatar
Here is the pieces I need. I checked inline tube and I don't think they have them. Hopefully I am wrong about this and someone will comment with a part number.
Old 02-06-2007, 04:40 PM   #8
oj70chevy
250 V-6 Club
oj70chevy's Avatar
not sure if this is what your looking for.
1970 Chevy C/10 6 Cyl. 43k original miles all factory .http://67-72chevytrucks.com/vboard/s...d.php?t=197523
Never ask a stupid question unless you want a stupid answer .
oj70chevy is offline   Reply With Quote
Old 02-06-2007, 05:38 PM   #9
JustLiveIt
JustLiveIt's Avatar
Yes i need the guide that goes on the end of the long rod on the passenger side in your picture. I have the rod just don't have the cable guide.
I am also missing the pigtail on the passanger side (not shown in your picture) as well that guides the cable through the cross member. It is a round piece of steel rod that goes through the frame but is bent at the end to form a loop for the cable to pass through. It looks like a pig's tail. See post #2 above. Post #2 shows the driver side but I need the passenger side.
Thanks for the picture! It helps clarify the cable routing for me.
Old 02-06-2007, 06:12 PM   #10
meathead95
computer illiterate
meathead95's Avatar
im getting a parts truck in next week so i should have one if you havent found it by then
72 2wd blazer
72 swb 4x4
Old 02-06-2007, 06:46 PM   #11
JustLiveIt
JustLiveIt's Avatar
Thank you meathead95!
Old 02-06-2007, 06:53 PM   #12
meathead95
computer illiterate
meathead95's Avatar
your welcome. pm me next friday so i do not forget
72 2wd blazer
72 swb 4x4
Old 02-06-2007, 08:26 PM   #13
High Speed low Drag
High Speed low Drag's Avatar
JustLiveIt-
PM me your address. I have what you seek. I will drop them in the mail Tomorrow or the next day.
Instead of $$$, all I ask is that you help the next guy/gal out.
Mark
High Speed low Drag is offline   Reply With Quote
Old 02-06-2007, 10:02 PM   #14
meathead95
computer illiterate
meathead95's Avatar
Originally Posted by High Speed low Drag View Post
JustLiveIt-
Mark
thats what im talkin about! that is very nice of you.
72 2wd blazer
72 swb 4x4
Old 02-09-2007, 01:59 PM   #15
JustLiveIt
JustLiveIt's Avatar
JustLiveIt-
Mark
Thank you to everyone who responded with offers to help me find these parts. High Speed low Drag PM'd me and he has sent the parts I need.
Gotta love this board and the people on it!
Old 02-09-2007, 07:11 PM   #16
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Is it bad that I don't have a "pigtail"? I've never had one in 4 yrs. Also, could this cause my pedal needing to go all the way to the floor? (It's adjusted correctly.
Sorry for the thread hijack. No I'm actually not sorry.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
