01-19-2006, 11:13 PM | #1 |
hood hinges ?
i have one hinge that you have to push down on the corner of the hood for it to close all the way. ? is can they be fixed or do you just replace.
01-19-2006, 11:24 PM | #2 |
Re: hood hinges ?
If oiling the pivots doesn't solve the problem, try adjusting the way the hinge is attached to the fender. It's held on there with three bolts; two in the back and one in the front. First try loosening the two back bolts and lift up on the hood so that the hinge lowers in the back, and retighten the bolts. If this doesn't solve the problem, loosen the top rear bolt and the front bolt, lift up on the hood again and retighten the bolts. By rotating the hinge back, the hinge has to fold farther when you close the hood, which causes the hood to be lower when closed. I have had this same problem on all three trucks I've owned. Making this adjustment fixed it on two of the trucks. The hinges on the third one were just too worn out.
01-19-2006, 11:45 PM | #3 | |
Son Of Gravel Man
Re: hood hinges ?
if there too worn out can you just get replacement springs or do you need the whole hinge?
Daily driven 70 C10 longbed Its a work in progress Quote:
01-19-2006, 11:55 PM | #4 |
its all about the +6 inches
Re: hood hinges ?
Just a spring swap might do the trick, but once in a while it still won't close all the way. Look for slop in the pivit points before deciding which to buy.
Also, some light oil on the pivit points goes a long way too. |
01-20-2006, 12:27 AM | #5 |
Re: hood hinges ?
Also pay real close attention to where the hinges bolt up on the hood. I had this problem for a couple years and was pullin my hair out tryin to fix it. One day while I was changin my blower motor I noticed the metal where the nut was welded on the inside of the hood was sheared about a little over an inch. Well one thing led to another and I ended up with a new hood.
2002 S10 ZR2 for the dirt. 1968 C10 shorty for the street. She said the truck would be the end of us. I still have the truck! |
01-20-2006, 12:39 AM | #6 |
Oil trash and damn proud of it
Re: hood hinges ?
aye, look out for them hinges. Reminds me of an experience with my 69 a few weeks ago... the rivet where the hinge swivels in the middle broke, so I rigged it up with a bolt and a nut. Well that didn't work the best, I guess, cause later sittin in McGreasers while my friend grabbed a burger, I went under the hood to play with my choke. Well as I went to shut it, SNAP! hood hinge breaks. Well, a "few" cuss words later, I drop him off, shut er down for the night. A few days later, I was taking her out for a test drive, and I was doing like 40, 45, down a road, when all of a sudden, WHAM!!! UP COMES MY HOOD! Talk about one hellride, can't see where I'm going, hood flies up on me, I swore I needed some new underware, I'm floorin that clutch and that brake, my friends ridin with me are about having as much of a ball as I am, my friend driving behind me just about craps his pants seeing this big red thing fly up infront of our heads in the truck, I'm slammin her down and get on a sidestreet. Wooh, talk about a fun time. That's when I said to hell with it, and just took her home and called her a day with that truck.
Good news is, my very good buddy 68350, let me have a hood hinge. To make that process even easier, I had a 2x6 that was the PERFECT length to prop the hood up on. So all's good now, except that I need to change my oil (fuel like hell in it) and possibly redo my valve cover gaskets. Otherwise, she'll be lookin good. Can't wait (then I can show off my new chrome) P.S. Oh yeah, if you learn anything about this post... oil... and if that rivet or something breaks, don't do what I did and just jury-rig that thing with a bolt, get a new one, haha
Mark 1997 K1500 Z71, 14 bolt SF 3.73 posi, Bright Blue Metallic. 6" Superlift 1972 C-10, toolbox, p/s, 350/TH350/3.73 open, black int., bronze 2008 Dodge MegaCab. H&S tuned 6.7 Cummins. Fast Four Tons Some of my pics http://s107.photobucket.com/albums/m294/69-350/ Last edited by 69-350; 01-20-2006 at 12:49 AM. |
01-20-2006, 10:56 AM | #7 |
Keep On Truckin'
Re: hood hinges ?
If you end up needing new hinges I would strongly suggest investing in GM brand hinges and they are still available from any Chevy dealer.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
01-20-2006, 11:02 AM | #8 |
More Cowbell....
Re: hood hinges ?
GM hinges also available form Chevy Duty. My local GM dealer wanted over $75 each. Chevy Duty is in the mid-$50's. And have all the "GM Parts" decals, tags, etc....
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
