01-19-2006, 11:41 PM | #1 | |
Son Of Gravel Man
Wheel Spacers
I think to fit the escalade rims I am going to have to run spacers
Any have any suggestion on these? http://store.summitracing.com/defaul....asp&x=22&y=12 Or http://store.summitracing.com/defaul....asp&x=21&y=10 Or is it better to scrap this whole plan and just get some thing different?
Daily driven 70 C10 longbed Its a work in progress Quote:
01-20-2006, 07:31 AM | #2 |
Re: Wheel Spacers
Take some measurements on the back spacing of the escalade rims and the rims you are presently running and see how much of a differance you have. Ihad to get some 1.5"& 2" spacers for my wheels that came of a 2000 chevy truck. look at this place for some good wheel spacers.
http://stores.ebay.com/CompleteValue...Q3amesstQQtZkm
70 C/10 SWB Go ahead chance it........Columbus did!!! Steve (Chitlin) Bacon My DIY Shop http://s24.photobucket.com/albums/c47/mpalmiter/shop/ |
01-20-2006, 11:13 AM | #3 |
Re: Wheel Spacers
agree, torque all to spec and you should not have probs
01-20-2006, 05:47 PM | #4 |
Dork For Days
Re: Wheel Spacers
I'm running some thin spacers on the rear of my truck simple cause Chevy liked to tuck the rears inside so much. It's not enough to make the fronts and rears equal, but it certainly helps - looks much better.
The BEST way is to get custom wheels made to exact specs so they fit perfectly. In the real (affordable) world, however wheel spacers aren't a bad way to go. I think the trick is to keep them as thin as possible, though. The thicker you go, to more you're loading your studs and the more likely you'll have a problem. I found that the thin ones (approx. 1/4") are thin enough that you can get away with the factory studs. You gotta make sure you have enough thread engagement!
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status! 1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60' 2007 Dodge Charger SRT-8 2008 Cadillac CTS All-American garage, baby! |
01-20-2006, 10:24 PM | #5 |
Re: Wheel Spacers
I had some aluminum ones that cracked and let a front wheel come undone. Killed a tire and flattened a brake rotor. The sparks looked cool, though.
01-22-2006, 12:06 AM | #6 | ||
Son Of Gravel Man
Re: Wheel Spacers
I was only thinking about the 1/4 in ones. I am not going to use any 2 in or more. I'll put them up on ebay and start over if that is the case.
01-22-2006, 01:01 AM | #7 |
Re: Wheel Spacers
Stay away from spacers greater than 1/4". Adapters on the other hand.... are ok until about 3".
