01-20-2006, 12:13 AM | #1 |
Active Member
Rear leaf arch 4X4-4X2
What's the difference between the arch on 4X4 vs 4X2 rear leaf springs?
I converted my 68 GMC 2wd to 4wd. The front axle and springs are from a 70 blazer, as is the t/case and 4 speed. The rear springs are the 2wd ones the truck came with, but I had to use 4" blocks in the rear to bring it level with the stock front 4wd suspension. Iwould like to put a 4" lift on it, but with the blocks in the back, more blocks aren't the answer. Would the rear leaves from a 4X4 make it right? And yes, adding the 4X4 front axle to the 2wd frame without another to look at or measure was a PITA, but it all works fine.
Never try to teach a pig to sing; it wastes your time and annoys the pig! Gets More Chicks My lugnuts require more torque than your honda makes! 68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4". |
01-20-2006, 09:45 PM | #2 |
Junk/Daily Driver Club
Re: Rear leaf arch 4X4-4X2
You need the rear spring, front hangers I have. They are off a 68 K-20. That will set the rear at the rite heights for 4X4. The one on the right is the 68 4X4.
Later Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker. There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened! Last edited by 67-72williso; 01-20-2006 at 09:50 PM. |
01-20-2006, 11:47 PM | #3 |
Active Member
Willis,
You say I need the set you have, is this a set like you used on yours or a set you have and want to get rid of? Thanks for the info....... Max
01-21-2006, 06:59 AM | #4 |
Max
Are your frame rails parallel or do they bow out at the rear axle area? These are off a parallel (4X4) so you might have to work on them a little that way. The heights will be correct thow. If you want them $25.00 to your door. Later Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker. There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened! |
01-21-2006, 11:03 AM | #5 |
Active Member
I'll go check the frame here later, but most likely I'll take them regardless,just need the buying info.
Thanks again..... Max
01-21-2006, 08:34 PM | #6 |
Max
One more thing I just thought of to is the spring width. 67-68 4X4 are 3" wide at the hanger area I`m gessing yours are 2 1/4". I gess you could use spacers there. Later Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker. There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened! Last edited by 67-72williso; 01-21-2006 at 08:35 PM. |
01-21-2006, 08:53 PM | #7 |
Active Member
Willis,
Yeah, it has zigzag frame and 2 1/2" springs.... I'll still buy your hangers and fab to fit. Need your info Thanks Max
01-22-2006, 10:54 AM | #8 |
The wider perches might help to adjust to the difference in frames.Another thought is there are shackle reversal hangers that give 4 or 6 inches of lift.They`re a couple hundred bucks.But if those perches don`t do the trick...
You say your lifting the truck 4",also,right?Either way,you could get away from blocks with these.BTW,welcome and nice truck.
