Old 01-20-2006, 10:51 AM   #1
rodstored-72
chevy truck fan
rodstored-72's Avatar
horn mounting question on radi. support???
hey guys & gals,
i am trying to put the front end back together on my '72 chevy 2wd truck. i can't remember how the pass. side horn assy. is mounted t othe firewall?? i am able t omount the driver's side horn, but i don't seem to see a bolt hole on the pass. side.
could any of you give me directions on where the horn is mounted???
oohh yea! i also am trying to put the radiator back in & when i bought the truck the lower radi. supports were not installed so could someone tell me how you "install" the lower radi. support mounts on my '72 chevy 2wd 1/2 ton pickup??
you guys & this site rock!!!!
thanks a bunch!!!!
rodstored-72
rodstored-72 is offline   Reply With Quote
Old 01-20-2006, 10:55 AM   #2
cdowns
cdowns's Avatar
Re: horn mounting question on radi. support???
both horns mount to the drivers side on the rad support//make sure to clean real well because the horn bracket to rad support is your ground for the horn
Old 01-20-2006, 12:52 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Yeah, I was having a problem as I read the note, about the right side horn. Now, I see that there is none. I took the horns off of a 50-series school bus, that I am going to install on my truck in place of the single horn it has. In addition, I have a Delco High C horn to add to the mix, giving it a Cadillac sound (tri-tone option on the Caddy's). So, I'll also be installing a horn relay to handle the current load.
Good Question.
Member Nr. 2770
Old 01-20-2006, 01:11 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
There is already a horn relay, all you need to do is wire it up.
Old 01-20-2006, 01:32 PM   #5
Bob Moore
The basic horn goes just outboard of the radiator - there is a captured nut about7 inches up from bottom of the core support. The optional horn mounts with a captured nut on the lower left of the headlight indentation on the core. The radiator brackets are usually rivited by the factory but use a thin head stainless 1/4-20 to attach to the core.
Hope this helps - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 01-20-2006, 03:55 PM   #6
rodstored-72
chevy truck fan
all,
thanks for the responses i will try to to use the info. tonight. this site is really really cool...
thanks again!
rodstored-72
Old 01-20-2006, 05:28 PM   #7
MrC1
Dork For Days
MrC1's Avatar
Talking Re: horn mounting question on radi. support???
It might be hard to reach when you want to honk if you mount it way up there.
Sorry, couldn't resist.
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status!
1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60'
2007 Dodge Charger SRT-8
2008 Cadillac CTS
All-American garage, baby!
MrC1 is offline   Reply With Quote
