Old 01-20-2006, 07:31 PM   #1
krue
Designated A-hole!
krue's Avatar
Plan B (or C or D, I've lost count)
I was planning on starting my disc brake swap this weekend by swapping the xmember from a 75 to my 70. After getting a good look at it I realize that it would need to be totally rebuilt (every bushing or joint is shot). So now I'm leaning towards using just the spindles. I have a 72 that I am gonna use the steering off of (in pretty good shape). Here's the question...will the 75 outer tie rod fit in the 72 adjuster (since I can't use the 72 outer tie rods in the 75 spindles).
Or should I just use the steering and spindles off of the 72?
Gimme some input guys.
BTW the objective is the cheapest way to get disc brakes.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 01-20-2006, 07:36 PM   #2
gentry69
gentry69's Avatar
Re: Plan B (or C or D, I've lost count)
is the 72 a half ton
gentry69 is offline   Reply With Quote
Old 01-20-2006, 07:38 PM   #3
72MARIO
72MARIO's Avatar
The 73 outer tie rod will not fit into the 67-72 adjuster sleve.
You can use the 73 up center link with 73 tie rods and spindles along with the 73 ball joints.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-20-2006, 07:47 PM   #4
krue
Designated A-hole!
krue's Avatar
Naah, that crap all needs replacing. Looks like it's the 72 spindles then. At least for now. Thanks for the info. I was leaning toward this anyways, now I still have a complete crossmember for whatever project I manage to sneak past my wife next (or maybe converting one of my 4x blazer frames to a 2wd? hmmm).
www.daveramsey.com
Old 01-20-2006, 08:27 PM   #5
Jim_PA
Exclamation Re: Plan B (or C or D, I've lost count)
67-72 didn't all use the same sleeve.
71 and 72 use an ES2004S sleeve, and the part number for a 75 sleeve is the same.
Jim_PA is offline   Reply With Quote
Old 01-20-2006, 09:05 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
If you think you might rebuild this front end some time in the future,... use the '73-up stuff. The later model stuff is cheaper at the parts store. And like Jim PA said, the '71-'72 sleeve will accept the '73-up outer tie rod. The '67-70 won't. (but a conversion sleeve is available for this swap.) Another thing to think about is all he associated parts you will need. New rotors? calipers? brake hoses? I would do some price shopping before you decide.
Keith
Convert to disc brakes.
Old 01-20-2006, 09:23 PM   #7
Jim_PA
It's not going to be cheap any way you do it, unless you just buy a 72 that has a really tight front suspension in it, and just bolt in the front end, and grab the other brake stuff off it that you'll need.
Any other way, and you are doing everything -- TRE's, ball joints, sleeves, master cylinder, rotors, calipers, spindles, prop valve.... you get the idea, and unfortunately it isn't cheap, but at least it'll be all new.
Old 01-21-2006, 01:07 AM   #8
72MARIO
72MARIO's Avatar
Jim are you 100 % sure on that ? I remember having issues getting the 73tie rod to fit the 71 sleeve.
2005 TAHOE DD
Old 01-21-2006, 09:10 AM   #9
Jim_PA
Look up the part numbers.
rockauto.com lists the same.
Old 01-21-2006, 09:16 AM   #10
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I like this one, why not if you have more than one at your disposal
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-21-2006, 09:54 AM   #11
mike nutt
69fatmotor
mike nutt's Avatar
krue , i installed a complete '85 xmember under my '69 ,simple bolt in , just two holes to drill. the rebuild kit is about a third the price . i also used the '85 power steering box.
mike nutt is offline   Reply With Quote
Old 01-21-2006, 10:29 AM   #12
There ya go,plan E?
