Old 01-20-2006, 11:31 PM   #1
Fl72Custom10
New Member
Fl72Custom10's Avatar
72 bed floor question - fleetside long bed
I've searched the forums but haven't been able to find the answer to this question. I'm in the process of restoring a 72 Custom 10 long bed. I have almost all the parts except the bed floor. The existing floor has rusted through. However, the sides are perfect so I hate to replace the entire bed. Is it possible to cut out a floor from a newer 8' Chevy/GMC bed, or a 67 - 72 if I can find a good floor, and have it welded to the '72? I don't want wood and I'm planning on having a spray-in bed liner. Thanks in advance for any advice.
Fl72Custom10 is offline   Reply With Quote
Old 01-20-2006, 11:46 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 72 bed floor question - fleetside long bed
You can do that, the sides unbolt from the floor and sub floor braces, maybe a couple spot welds to cut.
You could also do diampnd plate too. It'll be heavy, and kinda expensive, but it'll be indestructable, and with the spray/roll in bed liner, you won't have to worry about slipping like on painted diamond plate.
Old 01-20-2006, 11:51 PM   #3
truckdude239
truckdude239's Avatar
if thats not an option http://www.jcwhitney.com/autoparts/P...001014/c-10101
it is the sheetmetal shaped like our beds 20 buxs a sheet you just cut and form to your bed
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-21-2006, 12:33 AM   #4
Green Machine
Green Machine's Avatar
Those repair panels from Whitney are pretty thin, ok as small patch, but I wouldn't do whole floor with it. Somewhere I have seen bed floor half sections, a left and right, don't know the thickness on those, but you still need the braces underneath but they are being reproduced also.
Post on the parts board, someone may have a good floor for you. That would be best.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 01-21-2006, 01:50 AM   #5
MisterMan
MisterMan's Avatar
check ur local junk yards.. also check /w/ a LMC mag (i think thats it, i'm not at home so i cant check to see if they have them. or even if thats the right name)
MisterMan is offline   Reply With Quote
Old 01-21-2006, 11:06 AM   #6
I think the later panel would be workable.There`s a notch or two for the gas filler and it`s won`t be a perfect bolt-in.But,you`d have a good structure to work off of.I know the bed-mats pretty much fit.
