Old 07-17-2002, 11:44 PM   #1
matt_field
matt_field's Avatar
Unhappy name that noise!
its in my rear end, its wholing or however you spell it when you let off the gas? just replaced u joints and hanger bearing what else? rear end bad? can i just replace parts not the whole thing? thanks
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 07-18-2002, 12:01 AM   #2
da-burb
"Ochre Ogre"
da-burb's Avatar
"Howling" is the word I think you wanted. I am no differential expert, but it sounds like your ring and pinion are not aligned correctly. It could be worn out or it might just need shimming. It is probably cheaper to swap out the rear than to fix it, but then you could be buying more problems. Try to find an expert to take a look.
The easy thing for you to do is pull the differential cover and take a look for yourself. Look for metal shavings, worn gears, and rust pits on the gears. It's a start.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 07-18-2002, 12:12 AM   #3
matt_field
matt_field's Avatar
hey , thanks alot ill have to check it out
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 07-18-2002, 12:28 AM   #4
Blue_71
Bloo
Blue_71's Avatar
this is probably a stupid question, but you dont have knobby mud tires do you? they will roar like everything, and you might not hear it because the sound of the truck during acceleration
(edit for spelling)
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 07-18-2002, 12:32 AM   #5
bbs1965
Open Sundays 10 till 10
too bad your not close to Texas I have 6 lug rearends piling up on me. I can't seem to sell em.
bbs1965 is offline   Reply With Quote
Old 07-18-2002, 02:05 PM   #6
ThreeQuarter
ThreeQuarter's Avatar
Yeah, that howling comes from wear in the differential. I've had it in my last several trucks. Only one of them went out but it howled BAD for three years and 80,000 miles before it cratered. Have an expert check it out, or just turn up the radio. LOL
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
Old 07-18-2002, 11:31 PM   #7
matt_field
matt_field's Avatar
defeintly not tires, it gets weird sounding when you let off the gas like REALLY loud then kinda dies off, then not howling when gas on, id like a good rear end just to throw in it, or rebuild mine?
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 07-19-2002, 12:43 PM   #8
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Possibly Pinion bearing, time for rebuild or replace, they never get better only worse
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 07-25-2002, 01:19 AM   #9
GMC JUNKIE TOO
THE QUICKER FIXERUPER
GMC JUNKIE TOO's Avatar
mine howled then I put in straight lucas hub oil quieted it down. I had a guy tell me it was a worn pinion gear
GMC JUNKIE TOO is offline   Reply With Quote
Old 07-25-2002, 11:34 PM   #10
matt_field
matt_field's Avatar
new info, haha .. whenever i go around a corner it makes the noise the worst in thinking maybe bearing? or howabout the transfer case? anything go wrong in there? thanks alot
matt
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 07-25-2002, 11:51 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Most likely it is too late, but have you checked the oil level in the rear?
Old 07-25-2002, 11:52 PM   #12
jhwkns
Registered Cruiser
jhwkns's Avatar
Check your axle bearings Matt. If that's all it is it's a cheap fix. Good Luck.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 07-25-2002, 11:56 PM   #13
Zkast
Zkast's Avatar
Somewhat of an easy test, At around 25-30mph turn left, then right. If the noise is loudest when your turn right, the left bearing has a problem. If the noise is loudest when you turn left, the right bearing has a problem.
If you getting alot of howling from the rearend only on coast or decel, thats basicly the sounds of a worn rear-end. Its a combination of bearing (differential carrier and pinion) and gear wear creating too much backlash between the gears.
Bearings typicaly make a rythmic growning sound that comes and goes. The backlash problem just creates a loud howl that stays constant and is related to speed.
You if you catch it quick enough you can have someone that is experienced with differentials, replace all the bearings and check the teeth wear pattern.
Zkast is offline   Reply With Quote
Old 07-26-2002, 12:05 AM   #14
matt_field
matt_field's Avatar
the gear lube is full, its loud at coast, and at turning, maybe ill have a expert in town look at it thanks alot for your help guys!
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 03-12-2003, 05:22 PM   #15
71-longbed
Its Magically Delicious
71-longbed's Avatar
Unhappy
very similar problem with my truck.... sometimes it "clunks" when shifting from park to reverse....kinda hops forward after shifting into drive ...... how long do you think i have before it goes ???
very smooth shift between drive, L1 and L2..... ive found it clunks less when i move it from park to nuetral and then into reverse instead of just park to reverse.....does that make sense ?? any input on the subject would be great
thanks
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 03-12-2003, 07:27 PM   #16
The Terminator
thanks
I would call that a U-joint that was gong bad. Best -
The Terminator
John 3:16
1968 C10 SWB Stepside
The Terminator is offline   Reply With Quote
Old 03-13-2003, 04:00 PM   #17
AndrewDT
AndrewDT's Avatar
"its in my rear end, its wholing or however you spell it when you let off the gas? "
Matt, sounds like maybe you ate some bad chilie.
'72 Suburban 4X4
"Save the Earth, kill yourself"
AndrewDT is offline   Reply With Quote
