Old 01-21-2006, 09:21 PM   #1
bartstoy
bartstoy's Avatar
HEI Conversion
I am at the point of converting to HEI (some of us take longer than others)on my '69 BB. There seems to be two schools of thought. One is you throw out the old distributor and start over, the other you get a conversion kit and convert the old distributor. Anyone have any views on which is the best way to go? I am leaning towards the conversion because I just bought new MSD plug wires. But heck I have had to start over before.
Original owner '69 C20, long, fleet.
454 BB with Edelbrock stuff.
Work truck for years, 2nd restoration going on.
'69 C20
'03 Tahoe Z71
70 Hp Johnson pushing aluminum bass boat.
All things in life are uncertain, so eat dessert first.
bartstoy is offline   Reply With Quote
Old 01-21-2006, 09:29 PM   #2
Southedisto
River life......
Southedisto's Avatar
Re: HEI Conversion
I replaced my whole distributor.
Reasons:
1. I wanted a new distributor
2. I wanted an oil pump primer!
Southedisto is offline   Reply With Quote
Old 01-21-2006, 09:29 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: HEI Conversion
I say get an actual HEI, parts will be at any parts store where ever you are at anywhere in the US... if the conversion stuff goes bad (albeit, not often...but they will wear out) you won't have such luck.
Personally, i say hit the junk yard and look for a good unit, I always seem to find them with a new module and everything. Take parts from a couple cars in the junk yard, combine them to one dist, and walk out with new cap, rotor, module and coil... I've done it many many times myself.
Old 01-21-2006, 09:31 PM   #4
krue
Designated A-hole!
krue's Avatar
Re: HEI Conversion
What andy said makes sense and cents.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 01-21-2006, 09:45 PM   #5
Steelawork'n
Just hang'n around
Steelawork'n's Avatar
Re: HEI Conversion
I went new HEI because you get all new, shaft and everything. Rotate your old one and then rotate the new one...no comparison, new is better. You can put a spring kit in if you want.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year.
Steelawork'n is offline   Reply With Quote
Old 01-21-2006, 10:00 PM   #6
Longhorn Man
Re: HEI Conversion
While what you say is true... I can buy 8 or so junk yard units for the cost of one new one.
While my advice on this subject may not be the absolute best for some one, it may be the ONLY option for others.
What one man calls a budget part, another man calls his entire budget.
Old 01-21-2006, 10:34 PM   #7
67gmcss
Re: HEI Conversion
Is this conversion a simple yank the old one out and drop the new one in kind of thing, or what all does it require?
67gmcss is offline   Reply With Quote
Old 01-21-2006, 10:57 PM   #8
LMN8UR
LMN8UR's Avatar
Re: HEI Conversion
I got an HEI off of a 76 in the junk yard and then used it as a core at AutoZone, That was 95,000 problem free miles ago!
I definately recommend the complete change if it's finacially feesible!
Good Luck!
72 Chevy C-10 Custom LWB
383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb.
Hooker Comp Headers w/ X-Pipe and 2.25 duals
TKO-500 & 3.08:1 rear
I Love HEMI's, they're soft & chewy!
LMN8UR is offline   Reply With Quote
Old 01-21-2006, 11:06 PM   #9
bartstoy
bartstoy's Avatar
Re: HEI Conversion
Budget is tight but not restrictive if that makes sense. Thanks to all, going to check out the local yard and see what I can come up with. The last time I was there they had a pile of the things. If it can be used it will be, if not it will become a core. The BB is out of an '86. I knew I should have kept all the junk hanging on it. I am figuring on a new coil, gotta spend some $$ somewhere.
'69 C20
'03 Tahoe Z71
Old 01-21-2006, 11:08 PM   #10
jhow66
jhow66's Avatar
Re: HEI Conversion
You only have to change one thing--supply wire. Discard wire to your old coil-run a wire from switch on from fuse panel to "bat" on HEI cap -done.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-21-2006, 11:15 PM   #11
bartstoy
bartstoy's Avatar
Re: HEI Conversion
JHOW66 are you saying I don't have to change out the coil, or do I avoid that it by running the new supply wire? Sounds good to me.
'69 C20
'03 Tahoe Z71
Old 01-21-2006, 11:48 PM   #12
kevs_c10
kevs_c10's Avatar
Re: HEI Conversion
I've got a GM HEI from an 80's Monte Carlo I found at Pick-n-Pull. I bought my 350 from a guy that had it in a 90's Blazer so I replaced the electronic advance HEI with a vacuum model. I don't know if this is the route you're looking at or if you plan on going with an after market. If you use a stock GM, your old coil is a throwaway. The HEI’s coil is mounted in the top of the rotor cap. If you do get a salvage distributor keep a length of the wires leading to the cap so you can splice into them while using the original snap fitting wire end. Run a wire matching the gauge of the stock "bat" wire from the "on" side of your ignition switch to the piece of stock wire, splice it on with an additional wire of the same gauge running to the starter solenoid. When you start your truck the juice will flow to the starter solenoid, once started the juice flows to the HEI. The distributor should also have a terminal for a tach right next to the "bat" terminal. The change to HEI is well worth the effort, looks cool too.
1970 C10 Short Fleetside
kevs_c10 is offline   Reply With Quote
Old 01-21-2006, 11:48 PM   #13
Longhorn Man
Re: HEI Conversion
The old coil gets removed, as does the yellow wire, and the cloth covered wire.
All you'll need to do is drop the HEI dist in the engine and run a wire from the Ignition unfused terminal on the fuse box to the BATT terminal on the HEI's cap.
There's a lot written on this in the FAQ.
Old 01-22-2006, 12:34 PM   #14
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: HEI Conversion
Remember, just because you have a big block, don't limit your search. An HEI out of a small block will fit your 454 too. Much cheaper and easier to find.
Old 01-22-2006, 04:06 PM   #15
bartstoy
bartstoy's Avatar
Re: HEI Conversion
Thanks Tx, I was hoping someone would come up with that, cause that's all I could find at the yard. They looked at me kind of funny when I said I was looking for something out of a BB. No luck today, maybe tomorrow.
'69 C20
'03 Tahoe Z71
Old 01-22-2006, 04:20 PM   #16
l1n1b1
67 Shortstep
Re: HEI Conversion
I'm thinking of doing the same thing, except I'm doing it in a 250 6 cylinder. My question is: On a 6 cyl HEI, are the coils in the cap as well? Also what year/model of truck/car would have the 6 cyl HEI with coil in cap?
Bryan
67 SWB Step
69 LWB CST
71 LWB
94 SWB Step
05 1500 Dodge P/U
Adapt, Improvise, Overcome
l1n1b1 is offline   Reply With Quote
Old 01-22-2006, 04:31 PM   #17
LMN8UR
LMN8UR's Avatar
Re: HEI Conversion
There is no external coil on the HEI's. I told the guy at AutoZone I had a 76 and got a remanufactured HEI with coil for I believe around $80, but that was a couple years back.
Old 01-22-2006, 07:31 PM   #18
Tx Firefighter
Re: HEI Conversion
On inline 6 engines, there are two types of HEI's, one with internal coil and other with external coil.
They interchange and either works as well as the other. An HEI swap on an inline engine completely changes the personality of the whole engine.
Old 01-22-2006, 07:45 PM   #19
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Re: HEI Conversion
Daily driven 70 C10 longbed
Its a work in progress
pebbleboy is offline   Reply With Quote
Old 01-22-2006, 08:06 PM   #20
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: HEI Conversion
Go with the factory HEI and new wires then when the budget is right look into Pertronics distributors. I put one in and its new and nice.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 01-22-2006, 10:25 PM   #21
l1n1b1
67 Shortstep
Re: HEI Conversion
That's exactly what I thought on inline 6's.. ..Any advice as to what vehicles had the 6 cyl. HEI with the coil in the cap so I'll know what to look for at the junkyard? Thanks!
Bryan
67 SWB Step
69 LWB CST
71 LWB
94 SWB Step
05 1500 Dodge P/U
Old 01-22-2006, 11:09 PM   #22
Tx Firefighter
Re: HEI Conversion
I've had good luck with late 70's Novas. Look for the geeky brown 4 doors, they all seem to be inline 6 cars.
Old 01-23-2006, 03:46 AM   #23
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: HEI Conversion
Here is Shift's FAQ on inline sixes for HEI swap
http://67-72chevytrucks.com/vboard/s...d.php?t=148346
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-23-2006, 10:38 PM   #24
My72Cheyenne
"Work in Progress"
My72Cheyenne's Avatar
Re: HEI Conversion
If you get one from the junk yard, be sure to take it completely apart and check for wear. Once the bushings wear and the advance mechanism bushings wear, it won't advance right and could give you some trouble. I've rebuilt my entire HEI, and once I put a pencil to it, I think I could have purchased a brand new one for about $50 more. I would spend the diffenence next time and go new. That's my 2 cents.
72 Cheyenne 4x4, 350, th350, np205, factory air, tach, headliner, tilt
My72Cheyenne is offline   Reply With Quote
