01-21-2006, 11:08 PM | #1 |
Hot Rods For Life
PRogress on the Engine rebuild....
Well, slowly but surely, I am replacing my old broke motor (see pic) with a reman. I bought. I really don't have the money right now for a full resto so I am just trying to clean up a few things for my new(rebuilt) motor install. Once I get the motor painted and asembled, it will be the cleaned part of the whole truck. I figure I'll just do a piece at a time.
Anyway since I have the engine out I decided to clean up the oil and muddy mess left behind by the old motor. I can't really get to all areas with out totaly disassembling the front in so I am doing what I can for now. Should I repaint it or put some sort of coating? What about the areas I can't get the grease out? One of many dilemas. What I am doing is removing and painting the fender wells. I also decided to rattle can the outside of the truck with a Krylon satin paint. I am using it insted of primer. Seems to work ok and it's not glossy at all. Oh also check out the last pic. It's my tranny with a pretective shield of mud and dirt. Going to clean that up and replace the filter. |
01-21-2006, 11:25 PM | #2 |
Re: PRogress on the Engine rebuild....
gotta hate bad bearings. good luck to ya!
01-22-2006, 12:18 AM | #3 | |
no brain no headache
1996 GMC Sierra z71 1970 SWB 2wd (project) |
01-22-2006, 12:37 AM | #4 |
That sucks. Time to build some horsepwer.
01-22-2006, 12:58 AM | #5 |
Looks good Zumo. Keep @ it.
I like the satin touch to the fender.
01-22-2006, 01:03 AM | #6 |
User #12137
big ouch on the bearing
the fender looks good though |
01-22-2006, 02:33 AM | #7 |
Car O'Holic
wow that trans was covered!
01-22-2006, 07:32 AM | #8 |
The LuvShack Garage
Sheeesh, I agree with the others, what bearing
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
01-22-2006, 10:27 AM | #9 |
Hot Rods For Life
Yeah that bearing cuased a whole mess of trouble. My engine crapped out whil I was on the highway. It broke one of the brass keepers on the top of one of the valves which jacked up the valve area and even broke off some of the metal on the head around the valve.
The block may still be good but I am not sure. I went ahead and bought a remanufatured 74 (I believe) 350 4 bolt main with flat top pistons. The old engin was a punched out stock 307. As for the trans, I think this truck spent some time around the Red River area in Oklahoma be fore I got it. All the dirt I have been cleaning off the engine bay has been red. |
01-22-2006, 11:55 AM | #10 |
I am a Referee of life.
I would soak the whole thing with degreaser and go watch Horsepower.Then rinse and resoak.Leave it over night and do it again.I like paint to dress up the engine compartment.If you can tow it to the car wash or have a power washer it will come a lot cleaner.Hope you don't got ice.A wire brush and scraper first will make things go quicker.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 01-22-2006 at 11:56 AM. |
01-22-2006, 12:08 PM | #11 |
Watch out for your cornhole !
Plug the yoke hole and cooler line ports and use Easy-Off oven cleaner and the local car wash.
Go at night though, the car wash owners will crap a golden kitty if they catch you there doing that.
01-22-2006, 12:58 PM | #12 |
use a putty knife and i agree take the whole truck to a power wash, worth the effort, its funny the the comments you hear when you take a jack and jack stands with ya
67 swb gmc,big block cadillac powered,400 turbo,2.73 ratio and disc brakes-basically a frankenstein of many parts- |
01-22-2006, 01:01 PM | #13 |
Man Im about to have to do the same thing with my 84 and I cant afford it right now. It sucks.
01-22-2006, 10:40 PM | #14 |
Hot Rods For Life
My new neighbor 2 doors down has a pressure washer, I should take him some beer and see if he'll let me borrow it.
01-22-2006, 11:30 PM | #15 | |
01-23-2006, 01:00 AM | #16 |
Nothings as cool as my 72
That sucks about your motor dude. My tranny looked like that too. I used a putty knife and a wire brush, and that got most of the crap off. Then I would use ur neighbor's pressure washer to get rid of the rest of the dirt and grease.
1972 C10 Longbox In the middle of body off restoration Rebuilt 355, turbo 400, 3.42 12-bolt Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding. |
01-23-2006, 03:01 AM | #17 |
Saving 1 truck at a time!
Just a thought but I would service the tranny while you have it out and replace both of the shaft seals on the tranny. I forgot to do mine and one of them is leaking...bummer after you have the engine back into place. The shaft seals are so easy to do when the tranny is sitting in the bed of the truck.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
01-23-2006, 09:42 AM | #18 | |
Hot Rods For Life
01-23-2006, 11:20 AM | #19 | |
That first pic looks WAY too familiar. I bought a reman as well (autozone). $800 bucks was a lot cheaper than the GM blocks for $1600. (would of loved to have one, but a budget is a budget). My uncle was kind enough to pressure wash mine. I then used a drill to wire brush the frame. A coat of spray can primer and black paint. I went a little more in depth though. When I had the motor out I tore the entire suspension apart. Clean, sanded, primed and painted everything, added power disks, and bought all new suspension components (ball joints, tie rods etc...) Good luck gettin 'er all back together.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
01-23-2006, 11:58 AM | #20 |
Hot Rods For Life
I am seriously thinking about doing that to the suspension. It is also full of mud and grease. Seem so easy since it's all tore down. I did remove the fender wells and am planning on repainting those as well.
