ive tried to figure this out on my own and with my stepfather. but no luck so far. new voltage regulator new battery. i had the altenator tested it was "good" i think it may be the problem. im only gettn 12.40 volts while the truck is running(testing at the +bat post and the alt bracket, -bat post, ground stap, block water pump..IE i have an open circut good ground) im not sure whats wrong. when i switch on my lights....i get a screaching belt noise..so i think the alt needs to be replaced. .im about to loose it. so before i have to buy another part this month i thought id run it by you guys.
![]() Join Date: Sep 2005
Re: charging problem
if you are getting 12.40 volt with the truck running i'd check your grounds and cables. but i would look at an new alternator with built in reg the ext. regs aren't very stable heres the wirte up for it http://67-72chevytrucks.com/vboard/s...d.php?t=119379 go to the parts store and ask for a alternator off of a 83 chevy k-10 pick up 350 with internal reg mine ran 38 buxs with trade in be sure to tell them what year the truck you putting it on is to watch them freak out lol
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
its all about the +6 inches
Stupid Q... is the belt tight?
yup belt is tite as can be....
ok in that tutorial he says.
"Now the wire bundle that runs to your old altenator from the voltage regulator consists of the Red, White, and Blue wires."i have red white blue and black. i have the the white and blue plugged in the alt. the red hooked to the larger post on the alt. and the black hooked to the smaller post. is this rite. i asumed this was a ground for the alt. am i wrong. help me out fellas this has been a nitemare for the last week. thanx. again. |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Here is a great site to explain some problems. Hope it helps
http://www.madelectrical.com/electrical-tech.shtml
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
One trick I learned on an 86 Chevy was to disconnect the negative battery cable with the engine running (all power power acc. off including radio). If the engine stays running, the altenator is fine, if it dies, replace it with the Newer style with the internal regulator.
I also had an alterator that would test just fine at Schucks, but brought it to Napa and it was too low on amps, but would push the volts just fine. just my $.02..... ![]()
2017 Tahoe Premier - Daily '99 Silverado 2500 Wife's whip- 2020 Equinox Premier |
Unplugging the battery only tells you if your alt is putting out a couple amps. Which is not enough to charge the battery, or even run headlights.
Doing this can also burn up the diodes in the alt. |
#9 | |
![]() Join Date: Apr 2004
![]() Quote:
1968 Chevy 4x4 307 4 speed |
#10 | |
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 01-23-2006 at 09:06 AM. |
heres a picture i borrowed from the write up
71 K20 350/350/205, dealer air, 4" lift, Flowtech,Edel 1406 on 2101, procomp HEI,4.10's, 33x12.50x16.5 BFG MT's on slots. 4 wheel disc brakes. My lame K20 page My lame Eaton disc brake page ![]() |
#13 |
well i had the altenator tested twice. came back good. i guess my cable and grounds arent as good i think...ill be playn with them today i guess...
#14 | |
Msgt USAF Ret
Here is another good site to check for rewiring an alternator conversion. http://www.chevelles.com/techref/tecref14.html
#15 |
Good call Vet, I tend to leave that part out only thinking of our old stuff... but you are absolutly right on that.
#16 |
whats the reading from the battery suppose to be at idel? im getn like 12.45 and as low as 12.0. this alright..when the truck is reving its putting out more so i assume when its driving it should keep a good charge for radio lights and what not..so im not stranded...this sound rite? thanx w
#17 |
At idle, a good 13 - 13.5 is ideal, but a little less is to be expected in this old almost adequate set up. What does it go to once you are at speed?
#18 |
well last nite i did a deep cycle charge on the battery and put on a new belt. that seemed to work. at idel im gettn 12.75 with just a little gas its well in to 13volts. great. easy fix..thought i had serious problems...thanx agian. w.
