Old 01-23-2006, 03:29 PM   #1
caseyo
Carb Jetting, Brake bleeding
Hi all,
I recently replaced the brake fluid and now I can't seem to bleed the system. are there any tricks on this type of truck? Also, on my last car I was able to replace a jet in the carburator with a different aperature and it bumped my gas milage up about 5 MPG, any thoughts on if a similar modification might affect better milage.
thanks,
casey
caseyo is offline   Reply With Quote
Old 01-23-2006, 04:42 PM   #2
shelby987
shelby987's Avatar
Re: Carb Jetting, Brake bleeding
I can tell you that the following questions will be asked....what year is your truck, drum/drum or disc/drum. 4x4 or 2wd might help.
Specifics on the car that you swapped the jets out on, as well as your truck, gears, trans, engine, current carb CFM would all be helpful in giving you better answers to your questions.
GOOD LUCK and Welcome to the Board!
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 01-23-2006, 04:45 PM   #3
shelby987
shelby987's Avatar
oh yeah, for brakes, make sure you always start with the pass. rear wheel, move to the drivers rear wheel, pass. front wheel, and then the drivers front wheel when bleeding brakes.....which you might have to do if you got air into the system. If you fully drained the fluid, you might not have properly bench bled the mc or you might have over extended your mc while bleeding them in which case you need a replacement (recently had to do this myself, told its a common problem on older vehicles when you go to bleed the brakes).
as for the carb jetting....I have no idea, carbs are a mystery to me....but there is a thread floating around regarding putting acetone into your tank....but its at your own risk, and I can't remember the amount off hand.
