ECE shock kit
i got a 2-4 drop on my truck and need some shocks. Have any of you used the ece shock kit with all 4 shocks and the relocator kit. I was just wondering if KYB makes a quality shock??
Hootis is as Hootis does...
Re: ECE shock kit
I did the shocks, kit 2x4 drop, and the panhard kit on my 67. It works great! I also added the front sway bar, (it was the easiest item of all to install) and am VERY pleased with the results.
67 C10 LWB Fleet, 383, TH400, PS, 4BL-Holley, Headers & 3" Exhaust, 3" drop front, 4" rear springs, ECI shock relocate, Panhard Bar kit, wheels & tires 1995 Z28 Convertible - Borla, K&N, Lingenfelter Motor, C6 Wheels & Tires 1990 2500 4x4 Suburban 3" Catbac System, K&N, 2" Lift, Wheels, Tires |
67 is sold
Re: ECE shock kit
So you already have a 2/4 drop on your truck and are looking to replace the shocks?
The rear relocator brackets are required, unless you have them already. * moved to suspsension forum |
Re: ECE shock kit
I have used KYB's in the past and really liked them. The Gas-A-Just ones provide a firmer ride while the Gr-2's are softer.
"You can take the man out of PA, but you can't take PA out of the man" |
Re: ECE shock kit
its just the rolling chassis and i i dont have shocks on it right now. So whats the difference between the stock sway bar and the ece one..??
Re: ECE shock kit
They are the same if you can find a 1 1/4" factory sway bar. Look for one on a 3/4 ton. Same as ECE, BUT....BUT, ECE sells drop mounts for the sway bar that you need for a dropped truck.
For every person with a spark of genius, There are a hundred with ignition trouble. ![]() |
Outlandish Trends - FL
Re: ECE shock kit
You can also check out CPP, that's where I got my shocks and relocators. They have Doetsch Tech shocks. I'm happy with mine.
-Bret 67 short-fleet sold! |
Re: ECE shock kit
My truck is a 3/4 ton and is only lowered 2 in the front so would u still recomend getting the lowered brackets for the sway bar..Also what about the adjustable panhard bar.. Is that somethin u'd recomend for a 4 inch drop in the rear???
#9 | |
67 is sold
Re: ECE shock kit
With a 4" rear drop, ECE strongly recommends the adjustable track/panhard bar ![]() |
Re: ECE shock kit
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: ECE shock kit
I've used the ECE shocks bunches of times. KYB is top notch brand.
Please call ECE tech line and ask the guys your questions. I promise you, they will part any clouds in your mind. There's a reason they have a zillion loyal customers on here. Tell them the fireman sent you, they'll know who you're talking about.
