Old 01-23-2006, 05:37 PM   #1
Edmond
Edmond's Avatar
Rear Discs: How to connect brake lines?
I have finally put on the rear discs but now I need to connect the brake lines.
Maybe a dumb question but how can I do this?
Perhaps if any who has done this conversion already can tell me how they did it.
Did you used a brake hose with banjo bolt? If so, how did you connect the brake ose to the brake line?
Pictures would say more than a thousand words in this case..
Thanks in advance.
Cya,
Edmond
Dutch Longorn
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
1974 Chevy Camaro Z28 (Original)
The Netherlands
Edmond is offline   Reply With Quote
Old 01-23-2006, 06:10 PM   #2
matthufham
Re: Rear Discs: How to connect brake lines?
i've seen somebody use brake hoses for the front of a truck. it doesn't matter if they're hard or flexible, but you will be taking off the caliper eventually for pad replacement so i'd buy flex lines. build a bracket onto the axle tube or make a structure to hold what you currently have in the pic and connect a flex line. female to banjo it looks like you'll need
matthufham is offline   Reply With Quote
Old 01-23-2006, 06:19 PM   #3
Edmond
Edmond's Avatar
Front hose will not work. Front hose has flare, rear uses banjo.
Been trying to find a banjo to female connector all day, but I have not found one. Do they exist?
Cya,
Edmond
Dutch Longhorn
The Netherlands
Old 01-23-2006, 06:30 PM   #4
FormerMember
Use a front brake hose on each side of the axle, 81 Monte Carlo works well, as it's short. Banjo fitting goes on the caliper, other end of brake hose is female.
I mounted a front bracket onto the back end of the spring perch. Sadly, no pictures as the truck's gone.
FormerMember is offline   Reply With Quote
Old 01-23-2006, 07:17 PM   #5
RainFade
RainFade's Avatar
On mine I used the same soft rubber lines and banjo bolt that the front of my truck uses.
From the T fitting on the axle (that the soft rubber line from the frame connects to) I then used short pieces of pre-made brake line with the proper male fittings on each end.
I know you don't have a NAPA store around the corner in your country so perhaps some metal brake tubing and assortment of ends (got mine from SUMMIT) and a good flaring tool would be in order for you ?
Brian
71 K20 350/350/205, dealer air, 4" lift, Flowtech,Edel 1406 on 2101, procomp HEI,4.10's, 33x12.50x16.5 BFG MT's on slots. 4 wheel disc brakes.
My lame K20 page
My lame Eaton disc brake page
RainFade is offline   Reply With Quote
Old 01-23-2006, 07:24 PM   #6
drink2mny
drink2mny's Avatar
Raybestos Part #h5373 7/16 x 20 thread 1 1/16 long for a banjo bolt.
Use '76 dodge 1/2 4wd front brake hoses.
You are going to want to use new brake steel brake lines from the juction block above your axle/ attached to a bracket bolted to the cover.
Just measure from there to your calipers and subtract the length of hose.
Give me shout if you have issues...
Support The Board
drink2mny is offline   Reply With Quote
Old 01-23-2006, 07:27 PM   #7
Rdrdave
Broke and still trying
Rdrdave's Avatar
I've seen 4x4 front flex lines used on a board member blazer. There may be pics on here somewhere. I believe it was a blue 72 blazer with the light grey powder coated frame. It had the hard line mounted up at the cross sills instead of the diff. housing. Good luck
Rdrdave is offline   Reply With Quote
Old 01-24-2006, 03:13 AM   #8
Mudder
Mudder's Avatar
I used braided lines on mine.
Mudder is offline   Reply With Quote
Old 01-24-2006, 10:28 AM   #9
Edmond
Edmond's Avatar
Thank you all for the replies.
I have now two specially made short hoses with 7/16" banjo and female connector for the excisting brake line.
This should work. Will keep you updated on the progress.
(Sorry for the crappy quality of the pic, I made it with my phone)
Cya,
Edmond
Dutch Longhorn
The Netherlands
Old 01-24-2006, 05:41 PM   #10
drink2mny
drink2mny's Avatar
Nice..
Support The Board
Old 01-24-2006, 07:35 PM   #11
Edmond
Edmond's Avatar
Connected all the brake lines tonight with the help of Jan Suburban.
Will post pictures tomorrow. I am now officially a member of the 4 disc-brakes club.
Thanks for all the support!!
Cya,
Edmond
Dutch Longhorn
The Netherlands
Old 01-24-2006, 08:33 PM   #12
Chrome8
Chrome8's Avatar
Congrats on the brakes, can you let me know how they work? Are you using an adjustable prop valve? I talked to the tech guy at ECC today and he said that they lock up really easy.....this true or is he just saying that because they don't sell em?
1969 K20 not running, complete but rusty with wrecker boom and push bumper
1969 GMC C20 un-molested rust free original paint "a 4 eyed girl named 'Tina"
1971 Chev K20 4X4 Box Delete Commercial Truck Flatbed
"Choose a job you love, and you will never have to work a day in your life."
Confucius
Chrome8 is offline   Reply With Quote
Old 01-25-2006, 12:34 AM   #13
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
here's mine.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 01-26-2006, 12:26 AM   #14
roger0080
Mudder67, where did you get the cover or housing covering the rotor that the caliper mounts on????
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
Old 01-26-2006, 06:30 AM   #15
Mudder
Mudder's Avatar
They are the backing plates from the front. This is a 3/4 ton.
Old 01-28-2006, 03:57 PM   #16
Edmond
Edmond's Avatar
Rear doesn't lock-up, so I guess I don't have to use a different prop. valve.
As promised, a few pictures of the swap.
Cya,
Edmond
Dutch Longhorn
The Netherlands
Old 01-28-2006, 03:59 PM   #17
Edmond
Edmond's Avatar
One more...
Cya,
Edmond
Dutch Longhorn
The Netherlands
Old 01-28-2006, 05:20 PM   #18
drink2mny
drink2mny's Avatar
Great Job... I am glad all worked out for you..
Support The Board
Old 01-28-2006, 07:25 PM   #19
Edmond
Edmond's Avatar
Thanks! I'm really happy with it!!
Cya,
Edmond
Dutch Longhorn
The Netherlands
