Foom, foom, foom!
![]() Join Date: Mar 2005
differential question
Hello all, quick question, I had some gears installed last summer, do 3.73 gear normally make a humming noise? Or does this mean my gears need some adjustment?
Also what size speedo gear should I be running? Wheels and Tire are all stock size/height.
- Dan 84' LWB C10 // 2.5" from collector back. duel Turbo Mufflers // 350 w/ TH350 long Headers//3.73 rearend gears Future Mods 3/4 suspension drop ![]() |
BAD BOW-Silverado XST
Re: differential question
I've seen humming develop on high milage rears. Also when they have been run low on oil.
Visit this website to find the gears you need to correct your speedo. http://www.tciauto.com/tech_info/speedo_gears.htm |
Happy to be here
![]() Join Date: Mar 2000
I had a set of 3.73 Richmond gears installed in my 82 Blazer while it was still on the road. They had a lot more gear whine than the original 3.08's did. Is this what you are calling "hummimng"?
#4 | |
Foom, foom, foom!
I'll check my gear oil again, just in case. thx
