new guy intro
just joined and i just bought my dream truck a 1970 c 10 stepside. im a novice when it comes to working on her though. i picked her up for 4k and she looks almost perfect. body is straight and almost no rust at all. shes got a 292 staight 6 w/ headers and dual exhaust w/ 3 on the tree. plain jane farm truck i found in a classic trader. after driving her for a while here is the list i compiled to add..
-power steering -power brakes - rear roll pan -lower her -maybe convert to automatic -im building a custom fiberglass center console and adding buckets * any feed back for the most cost effective ways for my add ons will be great. i dont want to make her a hot rod but i want a hot truck to pull my bike around. any tips for cool add ons will be great too. thanks all! tessie and i appreciate this forum Last edited by tat2flash911; 01-24-2006 at 10:59 AM. |
Re: new guy intro
Cool Truck! Welcome to the board. Looks like you have a great starter truck.
Good Luck with it. You'll find plenty of people to help you out here. ![]()
Jamie Hyneman is my twin
![]() Join Date: Nov 2005
Re: new guy intro
Welcome from Colorado. I've always liked white trucks. Looks like you found a real nice ride. Keep us posted
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
Questionable
Re: new guy intro
Looks about like the find I made at the same price ( http://satellitehead.com/gallery ).
Power brakes is an easy upgrade, just costs money to buy the brake booster. Hookup is easy. Power steering is a little more expensive. I just swapped my stepside over, but I'm doing a radical overhaul on mine so it wouldn't be the same for you. Basically you'll need to swap out the gearbox and pitman arm and you'll need to get all the power steering brackets, pump/resevoir and everything for the inline 6, which is a pain in the ass to find ![]() New rear roll pan and the buckets are pretty trivial. For the automatic tranny, you'll need a new steering column with the linkage for an auto - might as well get one with tilt steering while you're at it. Again, expect to spend a couple hundred bucks. I also got rid of my 3spd tranny - you'll need to remove your transmission crossmember and move to an automatic tranny crossmember. Let me know when you get to this point, I can give supporting pictures or you can just look at my gallery above and see how I hacked mine out. I have a spare completely refinished and rebuilt stock automatic tranny crossmember I can sell you cheap with all the hardware. It may be necessary to get a new/used/modified driveshaft if the auto tranny is shorter/longer than the 3spd. That 292 is a great engine. Don't let go of it cheap. The 250's are a dime a dozen, but there is definite race build-up potential on the 292. I had a 250 in mine...
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
A.K.A- Crummy
Re: new guy intro
Nice original looking truck. Nothing wrong the way it is. Some truck rallies would help appearance(.02) Good find. Enjoy.
2003 Silverado Z71 Are fishermen all liars? |
Re: new guy intro
thanks shifty for the help and thanks to 68 and bound for the comments
67 is sold
Re: new guy intro
Very nice truck
![]() ![]() Stick around, there is a TON of information here ![]() |
Questionable
Re: new guy intro
hey - while i'm thinking about it, in case nobody els has told you there is a forum here that's in the main forum list. it's called the "FAQ" forum. here's a direct link, you might wanna bookmark it:
http://67-72chevytrucks.com/vboard/f...splay.php?f=28 Inside this forum is like...a whole ton of help threads that people have created which cover tons of topics. Since the search feature on the forum doesn't go back too terribly far, click on the "Sticky: FAQ Index thread" that's like ... four or five posts down on that page. Inside that thread there is a full text index of every FAQ/tech article that's in the FAQ. Here's a link: http://67-72chevytrucks.com/vboard/s...d.php?t=157669 One of the forum moderators, krue, does a killer job of keeping up on all that stuff. Whenever you're thinking, "man, I'd love to know how to do XXXXX", go search in that index post I just linked and you'll possibly find an article. Heck, even I have an article in there with tons of pictures explaining how to upgrade to using a normal distributor on that inline 6 engine instead of using the craptastic points+coil system you prolly got in it now. ![]()
Re: new guy intro
Very nice truck. I started with about the same ideas, upgrade my 68 K20 to pwr steering and such, went out to find a new front diff and ended up buying another truck that already had the auto trans and front disks, pwr steering. My thought was to pull the front clip off the 68 and put it on the 72, now I'm not sure. I'll probably end up with 2 separate projects, Good luck, this board is a great resource...
68 Chevy K20 72 Chevy K20 (new) 2000 Silverado Z71 |
Re: new guy intro
NICE lookin truck and welcome from Va.
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
Registered Cruiser
Re: new guy intro
Nice clean truck! Welcome..
I intend to live forever. So far, so good. |
Designated A-hole!
Re: new guy intro
Welcome to the board from South Mississippi. BTW check with putter on a cool roll pan for stepsides (it matches the bottom of the fenders) it looks good.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
#13 |
Designated A-hole!
Re: new guy intro
Here's a link with a picture of Putter's roll pan. I've seen it in person and it's sharp.
http://67-72chevytrucks.com/vboard/s...ghlight=putter
#14 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: new guy intro
Congrats and welcome to the board very nice looking ride...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#15 |
68 C/10
Re: new guy intro
Welcome to the board, and very nice find.
(2009) GMC Sierra Denali 6.2 AWD (67 C/10 fleetside SWB) (2018GMC Yukon Denali) Wifes Car |
#16 |
Aluminum slot wheels rule...
Re: new guy intro
Nice truck. Keep the 292 in it. Make it a "unique sleeper". Well-taken care of farms trucks IMO are usually the best. My truck was a farm truck, and the owner was so presice. Anyways nice truck. Definetly a keeper.
Just noticed: Look how NICE the bench seat is!! |
