VIN decode 1/2 or 3/4 ton
1969 GMC 4X4 Vin K9E1491106030
Can anyone confirm if this truck is a 1/2 or 3/4 ton by the VIN?
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
Gone Fishing
Re: VIN decode 1/2 or 3/4 ton
I came up with
4 wheel drive/v8/1/2 ton/stepside
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
Thanks, it is now a fleetside, but it is advertized as a 2500 1/2 ton and the picture does not show how many wheel studs there are.
Resident Curmudgeon
![]() Join Date: Dec 1999
PM board member Rod. He's got a lot of info on Canadian GMC Vins, he can probably give you some insight.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
I found the following link....
http://www.67-72chevytrucks.com/Chevyear.html Which indicates that it is a 1/2 ton! Bonus!
89 Chevy Suburban 4x4 ![]() |
PM'd you the answer..its a simple one..just that 9 after the K meant built in Canada (they "GM" did that on some 67-69 vins) on GMC vins...rest decodes like the boards decoders.
4wd, 8 cyl, 1/2 ton box pickup, 1969, built in Oshawa
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. Last edited by Rod; 01-24-2006 at 11:47 PM. |
