Progress Again, Finally
Well, I finally got my house and yard to the point where I can focus on getting my 67 Chevy nosed 71 GMC finished. I bought a bed from DJRacer, which I plan to get the sides straightened and use. I bought a good set of doors and a 67 chevy frame. I was going to re-use mine, but decided I could do more before disabling my truck if I got another frame. Below are some pix of the frame, I took everything off I don't plan on using, mocked in the new crossmember from ECE, and started wedding up all the un-needed holes in the frame. I am planning on boxing the rails and running ART a-arms along with air suspension.
1972 Blazer body...need to get a thread started for the rest of the story |
Re: Progress Again, Finally
More pix of progress and left over parts.
![]() Join Date: Sep 2005
coolness you going to sand blaster and paint the frame?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
So, far I have been using a 4.5" grinder with a wire wheel, it is coming really clean. I will see what I get when I am done. If needed, I will have it blasted. I think I might use silver por-15 because you can sand it and make the frame smooth, then I plan on painting over it.
Post Whore
![]() Join Date: Feb 2000
Always great to get back on a project. Keep us posted.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Congrats looks like you have a hellva shop with that house too...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
chevelito
bruddah..you got 1 too many trucks there. I'll take the one with the LT1 in it. lol. BTW, how did the engine turn out? I'm on the 4 year plan on mine. Just got done taking out the A.I.R. pump. What did you do with the EGR stuff?
Jay
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI |
Looks like you have a LS1 hooked to the engine hoist in one of those shots. Whats that plans for it? BTW looking good.
Brandon project 67 swb bagged on 20" Coddingtons |
Designated A-hole!
Progress is always good.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Jay-
The LT1 runs great. Have had a few growing pains with the truck, but none have been from the engine. I got block-off plates from Street and Performance. www.hotrodlane.cc project76- The LS1 is going in the truck with no bed. It has a long way to go. So far, I have all rust free cab, doors, and front sheet metal. I have a set of '04 GTO buckets seats in it (not mounted yet) and the dash cut out. The dash had a huge hole cut in the center and I am planning on doing a fiberglass dash/console in it.
1972 Blazer body...need to get a thread started for the rest of the story Last edited by NPilot1975; 02-26-2006 at 03:55 PM. |
Made some more progress this weekend. Got the frame notches in and once I notch the new crossmember for the driveshaft, I will get it welded in.
Few more pix of the finished notches.
1972 Blazer body...need to get a thread started for the rest of the story Last edited by NPilot1975; 02-26-2006 at 03:34 PM. |
#13 |
Questionable
got any pics of the seats and how they look right now?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#14 |
Shifty-
Here are a few pix of the seats.
#15 |
I am planning on running the seats without the headrests. I am hoping I can just replace the one piece of leather which will get rid of the headrest mount holes and the GTO embroidery.
#16 |
Questionable
how far from true are the bolt holes? Those look very similar to the set of seats that Foose put in the yellow '47 GMC or whatever on Overhaulin'
#17 |
The rear mounts on the seats are vertical, so I will have to fab some new mounts. I will have to look at it again for the front mounts, I don't remember. I am pretty sure that Foose uses Sparco seats, which look similar but are a lot more expensive and not 8-way power.
#18 |
why no head rests? if you get rear ended your head could break the rear window. but those seats are nice. how much did they run you and were did you get them?
