Low Hump or Tall Hump
Low Hump or Tall Hump, that is the question, what is the easiest way of telling which you would have? Does the low hump bolt on like the tall hump? I had ordered a new carpet back a couple years ago and it was the wrong one, I don't remember (AAADD - Age Activated Attention Deficit Disorder) which one I ended up using, I have a member interested in the one I do have but want to make sure it is the right one he wants so all is happy. Thanks
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: Low Hump or Tall Hump
Low hump is stamped into the floor not bolted in like the high hump.....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#3 | |
![]() Join Date: Feb 2005
Can you cut-out a low hump floor and bolt in a high hump floor? Is there markings or some pattern that you can use to cut out the hole? Thanks
#5 | |
Where's my beer?
Sure can! get a hi hump before the cutting, place it on top of your low hump cab, trace and cut, make sure you leave some extra sheetmetal for the bolts on the hi hump to hold on to. ![]()
Paul How do you make the invisible, visible?.........You take it away. |
Thanks Paul
Thought I heard of guys doing this, but wasn't sure. |
what determined if the truck got high or low hump? 4 speed or 4x4 got high or others as well?
common sense isn't so common anymore |
#8 | |
I think the only other one was BB auto. If I'm wrong someone will correct me.
I think the world needs a drink... ![]() Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd ![]() Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
its all about the +6 inches
big block/ auto
4X4 any 4 speed 1/2 ton V6/auto (GMC only) Any of the above, would be high hump. |
