01-24-2006, 11:46 PM | #1 |
20's and backspacing??
my truck is bagged and the frame is Z'd 3 inches what backspacing will work for my truck i was thinking about 4.5-5 inches but i dont know if there will be any clerance issue, the wheels and Billet Specialties Vintecs 20x8 up front and maybe 20x9.5 out back. any help would be appreicated. thanks
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
01-25-2006, 12:32 AM | #2 |
Re: 20's and backspacing??
With the changes made to your truck, I would suggest you physically bolt a wheel on that you know the actual measurements of & work from there.
You should be able to put a truck ralley (steel wheel) on & take some measurements where things are relative (suspension vs. sheetmetal). Add an inch here or there to arrive @ what works for your combo. I use stuff like pieces of wood taped to the wheek/tire to determine additional clearances required.
01-25-2006, 02:17 PM | #3 |
FnLow69, Where you at in Washington? I have a set of 20's that are the 9.5" wheels. I will find out the back spacing on them. If your close we can throw one on to see how they fit.
01-25-2006, 06:24 PM | #4 |
Im running 20x9.5 all the way around. 5.75bs up front 4.75bs out back.
Brandon project 67 swb bagged on 20" Coddingtons |
01-28-2006, 11:07 PM | #5 | ||
Son Of Gravel Man
Daily driven 70 C10 longbed Its a work in progress Quote:
