What is the trick with the Cat Wiskers?
Is there a trick to getting the outside rubber and inside cat wickers off
with out destroying them? Those little clips are crazy things!
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Happy to be here
![]() Join Date: Mar 2000
Re: What is the trick with the Cat Wiskers?
Yeah, you gotta put your foot on the cats head...
Keep On Truckin'
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
![]() Join Date: Oct 2005
![]() ![]() ![]() ![]() Grab it behind the head on the neck and pull them out quick,But watch out for the claws, They tend to get pissed when you pull there whiskers out.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod. ![]() |
What ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Like a Rock!
By design, they always seem to get bent beyond repair when removing. Luckily they are cheap to buy.
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! ![]() |
^ ya I killed one trying ! I guess I will kill all 4!
Re Order needed!
#8 | |
Son Of Gravel Man
Ok what are cat wiskers?
Daily driven 70 C10 longbed Its a work in progress ![]() Quote:
Post Whore
Ok look at a cat, you will see this long protrusions coming from the area around its mouth and nose these are called Whiskers
J/K I don't know what they are either, someone care to explain.
Drew '71 Chevy 350/TH350 Hugger Orange Currently just a rolling frame, body work soon to follow!!! Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927 Daily Driver: 1997 Chevrolet S-10 with more gears than pistons ![]() |
I think he means the fuzzy things on the inside/outside of the roll up side windows.
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
#11 | |
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
that's an old school term, "Cat Wiskers"........They are window felts or window wipes...........
1997 GMC Sierra Ext 1965 Mustang |
#13 |
you don't pull the cat whiskers out you just trim them.... they walk into walls that way..... or um so i have heard
2008 Ford FX2 Screw 1971 C10 project in shop now! 2004 Pontiac Grandam (wifes) 2000 Cavalier z24 (gas saver) |
#14 |
Yeh....and then tape bottle caps to the bottom of their little paws, and watch them dance.........
#15 |
GM ONLY BABY!!!
Aren't they also called anti-rattle modings?
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
#16 |
My main man around here who is 82, and knows all, and still works in the
garage all day on his chev truck and SWEET cars calls them cat wiskers. So I go with what he says.. Pic of his wrecker he drives to haul the parts out of his yard... When the bees sting him he eats the fn bee..... man he is the best.. Here kitty kitty kitty..... ![]()
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD Last edited by 67chevemall; 07-09-2010 at 02:27 PM. |
#17 |
I'm not sure I would try pulling the whiskers from that cat. I mean, I do have limits, And that one looks pretty nasty.
