Old 01-25-2006, 05:11 PM   #1
c10crazy
Like a Rock!
c10crazy's Avatar
Question Installing Rear lowering coil springs
Can somebody tell me the steps to do this on a 69' longbed?. I know I can handle this without paying a professional but have never done it before. Please help
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 01-25-2006, 05:31 PM   #2
see ten
WTB this ad
see ten's Avatar
Re: Installing Rear lowering coil springs
If all you are changeing is the springs, you unbolt the old and bolt the new back in. If you are changeing the shock mounts and the track bar it gets a little more complicated. It is still a project you should be able to handle with a little time and basic tools.
see ten is offline   Reply With Quote
Old 01-25-2006, 05:49 PM   #3
c10crazy
Like a Rock!
c10crazy's Avatar
see ten, I'm just swapping springs only. Am I supposed to put the jack under the pumpkin to take pressure off the springs?. Can they fly out at any point during install?. Sorry for the dumb questions but I have never done suspension work and need to go one step at a time. I've searched the board for past posts and couldn't find any directions.
69 LWB
Old 01-25-2006, 06:15 PM   #4
Joe67
67 is sold
Rear coil spring replacement is very safe. It isn't any where near dangerous as the fronts.
He pretty much explained it. I've had mine in and out a few times now
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 01-25-2006, 06:23 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You'll need jackstands under the frame and the jack uner the rearend.
Just unbolt the spings top and bottom and lower the jack to let the rear end down. Now, replace the springs and jack the rear up into place again.
Use plenty of penetrant on the bolts and nuts.
Old 01-25-2006, 11:46 PM   #6
c10crazy
Like a Rock!
c10crazy's Avatar
I think I understand now:.
1. While it's jacked up under the pumpkin with the springs compressed I unbolt them then lower to relieve tension which allows them to fall out.
2. Then sit the new springs in there and jack up to compress the new springs.
3.While the new springs are compressed I put the bolts back in.
Is this correct???
69 LWB
Old 01-26-2006, 12:02 AM   #7
Tx Firefighter
100 percent correct
Old 01-26-2006, 12:43 AM   #8
c10crazy
Like a Rock!
c10crazy's Avatar
Sorry it took so long to sink in . Thanks for walking me thru it
69 LWB
Old 01-26-2006, 01:06 AM   #9
68haywagon
I'm watching you!
You don't need to put any pressure on the springs to bolt them. There is no need to compress them, bolt it on top first the raise the trailing arms and rear until the spring touches and bolt the bottom.
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
