Old 01-25-2006, 08:43 PM   #1
myersjeremy
myersjeremy's Avatar
Popping out of 4 wheel drive
Is it just an adjustment when a truck pops out of 4 wheel drive? I had the tranny replaced in my 85 and now it pops out when i put it in 4hi or lo....makes no difference. It looks like something is out of whack because to lock it into 4 hi it is almost lined up with the 4 lo selection on the console. Any help would be appreciated....
Jeremy
myersjeremy is offline   Reply With Quote
Old 01-25-2006, 08:56 PM   #2
Smokin85
Re: Popping out of 4 wheel drive
Sounds like the linkage may need to be adjusted. Its a fairly simple thing to do.
Smokin85 is offline   Reply With Quote
Old 01-26-2006, 12:29 AM   #3
Russell
Professional Grade
Russell's Avatar
Which transfercase do you have?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 01-26-2006, 10:59 PM   #4
myersjeremy
How can I figure out which transfer case this is? Its mated to a 700R4
Old 01-27-2006, 01:17 AM   #5
Russell
Professional Grade
Russell's Avatar
First question -- Full time or part time?
Second question, is there a little round cover with 3 bolts on it on the back side of the t-case between the upper and lower shafts?
Old 01-27-2006, 07:23 PM   #6
Scrubby
Check out GMTrucks.org
If it is the stock case in that truck, I bet it is a np208. I think you can adjust the linkage on that one.
Scrubby is offline   Reply With Quote
