Where is my washer fluid pump?
My truck does not appear to have a washer fluid pump. Where would it normally be located? If mine was yanked, has anyone ever installed a modern universal pump, and where did you put it?
thanks Mark 1970 C10 |
Re: Where is my washer fluid pump?
should be on the driver side...
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
It`s attached to your wiper motor.
#4 | |
Son Of Gravel Man
Mine was under the dash just to the right of the gauge cluster. not real hard to get to.
Daily driven 70 C10 longbed Its a work in progress ![]() Quote:
#5 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
#6 | ||
Son Of Gravel Man
More than one,lol.Easy access to right side of your motor,eh?
67-72 Addict!
I'll be watching this post to see if anybody suggests the remote mounted universal pump. I have heard it's an easy mod.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
I put a universal pump under the res. beside the volt reg.
In bad weather I have a hose that connects under the hood and a magnet/sqirter I put on the truck.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
![]() Join Date: Feb 2004
It's under the dash, to the right of the cluster, if your sitting in the driver position it is down and to the left of the radio. There are a couple of screws that require a very small socket or screw driver. Mine was next to the wiper motor, the toughest part was getting the hose debris out of the way. When installing a new or rebuilt be aware that there is a gear that needs to be engaged for the thing to work.
Original owner '69 C20, long, fleet. 454 BB with Edelbrock stuff. Work truck for years, 2nd restoration going on. '69 C20 '03 Tahoe Z71 70 Hp Johnson pushing aluminum bass boat. All things in life are uncertain, so eat dessert first. ![]() ![]() |
More Cowbell....
I am putting an electric one from a mid-90s S-10 on my stock bottle. Just remove the pump and the rubber gromet/gasket from S-10 washer bottle. Drill the exact same size hole in the stock bottle at the bottom, install gromet, install pump, run the hot wire from totally trick "Putter's Delay Wiper Switch" and voilla.....new electric pump that squirts like a sumbeach.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
#12 | |
Where's my beer?
I'm gonna have to hit you up when I get to that stage in my truck in case I have any doubs, great post! ![]()
Paul How do you make the invisible, visible?.........You take it away. |
#13 |
"Trucks with Class"
![]() Join Date: Jul 2000
Here is the little black elec pump that I am using. It almost doesn't show and fits right up next to the stock bottle. I wire it into the wiper switch so when you press the switch it pumps and it doesn't keep going like the original. I can never keep the original ones working.
If anyone needs a change over system: directions, pump, color coded wires, connectors, hose "T". You can plug it in without cutting any of the original stock wires and the two speeds still work as designed. I can put a set together, box it and ship it to you for $30, if you don't want to go through all the hassle of figuring it all out, up under your dash. Just let me know if you want one. |
#14 | |
I did a JY one. Got a washer pump from an old BMW (I think). Tim
1972 Suburban C20 454/TH700R4, eaton-corporate 4.10 (looking for 3.7) Sold: 71 Cheyenne 20 Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005) |
#15 |
71400lb
My original pump wouldn't stop pumping...so whenever the wipers were on, it would squirt until the resevoir went dry!
So, I bought a $14 universal washer pump at Advance Auto. It's a little fatter than a roll of quarters. I mounted it to the inner fender, found a fuseable link coming off the battery wire...grounded one wire and ran the other one to a throttle type switch under the dash. Of course I re-routed the hoses to the new pump...Now when I want to spray the windshield, I flip the switch up, and voila, the windshield gets sprayed. I like it because it's totally independent of the wipers, unlike the stock setup. Rick 1971 Cheyenne 3/4 Ton 2wd Long Bed 400 SBC |
#16 |
Great ideas.
Where were all of you when I was fighting the reinstall of a rebuilt pump with my fat hands under the dash, in a contortionist position? And how about those two "stinking" little nuts that hold everything together? Will never do that again.
