Junior Member
60' Front suspension?
I have a good 60' apache c-20 that I am starting to restore. I have several 1/2 ton coil spring rearends to swap out the 8 bolt low geared rearend, but I was wondering about the frontend. The 60'- 62' have a different front suspension than th 63'-72'. Will the 67'-72' fronts bolt under the 60' or can I put 1/2 ton spindles and 5 bolt hubs on the old 3/4 front
Old Chevys never die they are just reborn! |
Re: 60' Front suspension?
mine has a 77 frontend in it . i just swapped upper and lower a-arms,spendles and hubs. bolted right up.
try asking at www.chevytalk.com
1964 c10 short step 1962 econoline van 1989 rs camaro 2006 yamaha vino 125 1975 goldwing |
