Old 01-26-2006, 12:02 AM   #1
70c10
67-72 Addict!
70c10's Avatar
Copper oil pressure line
I'm installing an aftermarket oil pressure gauge under the dash and I ran the new line from the manifold into the cab but have like 3 feet extra line. Should I just cut it short and keep the line straight or does it matter if I coil it behind the dash?. The reason I'm really asking is I can't find my tubing cutter
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-26-2006, 12:04 AM   #2
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
Re: Copper oil pressure line
Coil it.
You can always cut it shorter at another time.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 01-26-2006, 12:57 AM   #3
cduster
Coiling it in loops will help to relieve the vibrations so it won't crack as easy.
Same principal as some brake lines, and primer lines and fuel injection lines on airplanes.
Dan
Good Judgment comes from experience.
Most experience comes from bad judgment.
cduster is offline   Reply With Quote
Old 01-26-2006, 01:21 AM   #4
rkarr
rkarr's Avatar
Dan
Copper is always happier when coiled.
Avatar is a pic of "Before"... Just wait..
1969 Fleetside:
Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans.
20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit).
Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all
Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!!
rkarr is offline   Reply With Quote
Old 01-26-2006, 08:45 AM   #5
70c10
67-72 Addict!
70c10's Avatar
Thanks. I will coil it behind the dash cluster. Does it matter if the line is looped vertically to save space?
Jim
Old 01-26-2006, 09:00 AM   #6
cdowns
cdowns's Avatar
you should actually coil it in the engine compartment between engine and firewall is where you have the vibration and flexing occuring causing the cracking of the pressure line
Old 01-26-2006, 09:09 AM   #7
70c10
67-72 Addict!
70c10's Avatar
Mine is coiled like that up to a connector. From that connector I ran the "new" copper line into the cab and that's why I have this left over line.
Jim
Old 01-26-2006, 09:22 AM   #8
Luvlegs
Luvlegs's Avatar
When you coil copper, lay a line of silicone across the coils (ties them together) - It changes the resonance of the coil and eliminates vibrational stessing that WILL cause the copper to harden and eventually, crack. Look at any refrigeration system with coiled up pressure lines - real easy pm and that's my .02
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 01-26-2006, 09:49 AM   #9
70c10
67-72 Addict!
70c10's Avatar
Maybe I should have just used the plastic line that came with it.
Jim
Old 01-26-2006, 10:33 AM   #10
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
If you ever had one break or come loose and shoot off in your floor board you wouldnt say that.LOL You can use the edge of a file to score a ring, to cut small copper tubing.
sneakysnake is offline   Reply With Quote
Old 01-26-2006, 02:04 PM   #11
davidh
davidh's Avatar
I plan on swiching my plastic ones to copper. The plastic ones don't age very well, all the heat stresses them. If it blows or breaks it will make a real mess quick. Anyone one with a copper line have experience with their reliabiltiy?
davidh is offline   Reply With Quote
Old 01-26-2006, 04:26 PM   #12
70GMCer
70GMCer's Avatar
This is how it looked from the factory. I took this off a 68 C20.....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-26-2006, 07:15 PM   #13
70c10
67-72 Addict!
70c10's Avatar
Steve, my factory one looks identical. See the junction 6" above that spiral- I ran my new copper from that junction into the cab. Once inside the cab I guess I'll coil it up several times and hide behind the dash.
Jim
Old 01-26-2006, 07:34 PM   #14
70GMCer
70GMCer's Avatar
that'll work.......
1997 GMC Sierra Ext
1965 Mustang
