barn door conversion
my bro wants to convert his tailgate 82 burb to barn doors, what all is involved, thanks, brian
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: barn door conversion
There is too much involved to make it worthwhile. Tell him to go find a barn door Burb and fix that up..
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#3 | |
![]() Seriously, though. It's not easy like it might seem. The factory welded different pieces into the body for the two setups.
Semper Paratus |
he found out it ain't easy, the lower panel will have to be swapped & he has to get the nut plates that bolt on the doors. he has them "on" now, just another trip to the yard for the lower panel. brian
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
If it was a pre-80 model it would be alot easier. Most came with both hole/plates installed.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
the toughest part is changing the panel under the doors/taiilgate, they are different. brian
i've done one not worth the time along with the lower plate there is also a crossmember under the floor that has to be changed you have to buy the crossmember new it's about 250.00
