69 Disc Brake/ Lowering Pictures
I have a couple of pictures of the Disc Brake conversion and the lowering springs. I would like to also add that this 3/4 ton lower A-Arm conversion is pretty slick. It is very easy to install. Other than my son almost lowering the truck on me it went without a hitch. The truck didn't just lower 3 inches it lowered about 5 inches because I went from BB chevy springs to 3 inch SB lowering springs. I am going to put what I used as far as parts go in case anyone wants to try it.
Used Parts 69 Chevy 3/4 ton Lower A-Arm 1988-1993 3/4 ton 2 wheel drive Spindles, Calipers and Rotors. (Rotors are six lug rotors but the lug size is Metric so you need different size lugs). New parts 1988 to 1993 Inner and Outer Tie Rods 1988-1993 Inner and Outer Bearings and inner seal 1988-1993 Upper and lower Ball Joints JRB |
![]() Join Date: Aug 2005
Re: 69 Disc Brake/ Lowering Pictures
Where's the money shot?
Yet to come. I need to get it out of the garage before I do that!
JRB |
