01-26-2006, 01:32 PM | #1 |
How Low Can I Go?
How much notch can I run on the back of my frame without the rearend contacting the bed floor? I am going to run the stock 12 bolt rearend and don't want to cut the floor. Thanx
1972 Blazer body...need to get a thread started for the rest of the story |
01-26-2006, 02:02 PM | #2 |
Re: How Low Can I Go?
I think mine was a 3" notch and if the axel was to bottom out it would have hit the floor.At that point I decide to just keep running around with the 2-3" of travel I have now.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-26-2006, 05:05 PM | #3 |
WTB this ad
You can always go with the 4x4 guys trick of "shaving" the differential. Of course you would be doing the top instead of the bottom. If you do a search I am sure you can find some info about this. Some of the extreme 4x4 crowd actually shave off the bottom of the differential. I have seen as little as .5" to a couple of inches. Some people take off some with a sawzall and then weld a reinforcement plate across the bottom. I have also seen them just grind off the excess casting across the bottom of the chunk and cover. I am sure this same principle would also apply to the top. I don't have any experience with this so I can't vouch for it. But if guys with monster tires who are dragging their diffs over rocks can do it, I don't see why a lowrider needing an extra inch or so of clearance couldn't do it.
