Old 01-27-2006, 01:29 AM   #1
rick0312
rick0312's Avatar
69 c10 power steering fluid
My power steering pump says to use "Type A" Transmission fluid. trouble is I can't find this type of fluid....only type F. Can i use regular power steering fluid or will this damage the pump?
rick0312 is offline   Reply With Quote
Old 01-27-2006, 02:08 AM   #2
al's71gmc
4 eyed fever
al's71gmc's Avatar
Re: 69 c10 power steering fluid
Maybe look into power steering fluid, instead of atf ?
1971 GMC 2500 4x4
1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto.
4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!!
al's71gmc is offline   Reply With Quote
Old 01-27-2006, 12:11 PM   #3
Woody
Use only Power Steering Fluid, not ATF. ATF will foam and not work well at all. I have been wrenching on cars/trucks for 30 some yrs. and I thought ATF would be ok. Then I used some ATF when I swaped steering boxes. Big mistake!! Pwr steering fluid is made to handle a lot higher pressures then ATF. I had to use a suction gun (looks like a grease gun ) to remove the ATF then replace it with the PSF.........
Woody is offline   Reply With Quote
Old 01-27-2006, 01:04 PM   #4
rick0312
rick0312's Avatar
Woody, Thanks for the advice....I'll go and pick up some power steeriing fluid!
Rick
Old 01-28-2006, 07:31 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
funny thing is though, these were designed for dextron... not the thicker (harder to push) power steering fluid.
Yes, dextron will foam, but, only if there is air in the system, which...as you know, indicates something wrong. (or just putting it together and needs bleeding still)
I have also been turning wrenches my entire adult life...last 15 years or so, and use what ever the factory recomends... or what ever is already in the system. Some big trucks use motor oil... just depends on what system you are dealing with.
Nothing but dextron in mine. I checked with bvot the caddy parts (pump) and the chevy parts (everything else) on my trucks, and it all called for dextron.
Old 01-28-2006, 07:38 AM   #6
70GMCer
70GMCer's Avatar
I've always used "Dextron" trans fluid in mine for years without any problems.....also, he didn't say if he needed to add fluid to the pump, which might already have trans fluid in it. I don't know if mixing trans & pwr fluid would do harm.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-28-2006, 12:00 PM   #7
richierlb
a;son if you look on the back of a dexron mercon bottle it usually tels you that it replaces de/mer/type a just a little info to pass on
richierlb is offline   Reply With Quote
