![]() Join Date: Jan 2006
seam sealer
![]() thanks Rick |
Re: seam sealer
3-M makes a good seam sealer so your store should have it ,I got mine from NAPPA
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
Re: seam sealer
a local auto paint supplier will have a better selection of premium grade products than peppys
Re: seam sealer
I'd go with the 3m its the best i've run across, and you can get it just about anywhere.
Kevin 1967 C-10 swb fleetside 1968 C-10 stepside 1999 Z71- sons dd 1999 2wd silverado-my dd 2003 Tahoe- wifes dd |
Re: seam sealer
thanks for the info!!! I'll go with the 3m
Re: seam sealer
I agree about 3M, but you should ask the dealer for suggestions on which type to use depending on where you are using it. In the 3M brand, there are many different styles. Some will set up hard and are not paintable where others are soft and are paintable. There is even a self flowing seam sealer.
![]() Join Date: Aug 2005
Re: seam sealer
3M 'Drip-Check' is what I usually use. It flows into the seem well, and it can be painted over. Many sealers, particularly silicone based types, cannot be painted over. Good advice is to go to an auto-body supply shop. Some NAPA's do, and they carry 3M products.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
