Old 01-27-2006, 09:20 PM   #1
pjmoreland
pjmoreland's Avatar
Disc Brake Pad That Doesn't Get Rims Dirty?
The front disc brakes on my truck get my alloy rims dirty very quickly. Is there a disc brake pad material that doesn't do this?
pjmoreland is offline   Reply With Quote
Old 01-27-2006, 09:33 PM   #2
matthufham
Re: Disc Brake Pad That Doesn't Get Rims Dirty?
they make covers that go behind the wheel and act as a shield. basically you can no longer get brake dust past that onto the visible part of the wheels.
then there's drums and those are your choices.
you can coat your rims with stuff to prevent brake dust from ruining your wheels, or buy wheels with no holes like my centerlines (click my pink name to the left to view a pic in my public profile)
there's nothing you can do to stop brake dust from happening, it's a bi-product of the pads slowly falling apart
you can stop it from forming in such large quantities with light braking and constant car washes.
matthufham is offline   Reply With Quote
Old 01-27-2006, 10:08 PM   #3
pjmoreland
pjmoreland's Avatar
I have an Acura Integra with alloy rims and the front wheels don't get dirty at all. I don't get it.
Old 01-27-2006, 10:11 PM   #4
The Integra is really light.The brakes will probably last forever,too.The main thing is to stay away from metallic pads.
Old 01-27-2006, 11:13 PM   #5
chaosdsr
chaosdsr's Avatar
actually a pad that will put off less dust is the ceramic pads. Akebono makes them along with a few other companies depending on what you have for a disc brake setup they are available for the older style gm calipers. Ceramics give off about half the dusting which is why most newer cars and imports dont dust bad due to the fact that they come stock with them.
chaosdsr is offline   Reply With Quote
Old 01-27-2006, 11:41 PM   #6
see ten
WTB this ad
see ten's Avatar
I have heard that when you run ceramic pads the rotors usually have to be replaced when you replace the pads. I have NO idea if there is any truth to this. Just one of those things I heard in passing.
see ten is offline   Reply With Quote
Old 01-28-2006, 12:02 AM   #7
powell72
powell72's Avatar
The ceramic pads do produce very little dust but are hard on rotors. I would rather use a lower grade pad and save the rotor.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 01-28-2006, 12:24 AM   #8
jostrans68
Jostrans68
jostrans68's Avatar
we have a Kia sportage with serious dust issues the pad I was told to use is bendix titanium they are supposed to be good
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
