Old 01-28-2006, 01:43 PM   #1
desertlobo
Need Help
This is my first post because I am final going to get my 68 c20 on the road, my 15 year thinks its his but what he doesn't know won't hurt him!!
My truck is going to be used for strickly street in Phoenix so I have a question.
I want to put a c10 rearend either 5 or 6 lug in it assuming it would be better in the long run for the street. Also I plan on putting disc on the front so I have to get rid of the rear 8 lug in the rear. Any suggestions. I am going to drive 200 miles to buy the c10 rearend out of a 78 chevy tomorrow so any help would be basically life saving.
desertlobo is offline   Reply With Quote
Old 01-28-2006, 03:08 PM   #2
sdkid
Re: The unknown
That 78 will be leaf spring. If you have a chevy it is coil spring. Modifications will be needed to install the 78 diff.
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 01-28-2006, 03:19 PM   #3
desertlobo
Re: The unknown
On my 68 it is leaf spring I went and looked.
Old 01-28-2006, 03:19 PM   #4
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Re: The unknown
C20 could be a leaf spring rear so it may not be a problem. Check on your glove box door to see if you have the Eaton, Dana, ratio and posi if it listed there. It could be worth something to those of us that are doing stock c20 restorations.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 01-28-2006, 03:25 PM   #5
desertlobo
Re: The unknown
No problem I'll check now
Old 01-28-2006, 03:37 PM   #6
desertlobo
Re: The unknown
I checked and all they have on the glove door is the option numbers.
Old 01-28-2006, 03:43 PM   #7
stllookn
stllookn's Avatar
Re: The unknown
Can you tell by looking if it is an Eaton or Dana? Eaton has the round cover. You will probably have to pull the cover to determine if it has posi. Is it a big block truck? '68 C20 4.10 - HB8, NoSPIN 4.10 - G86, POWR-LOK w/396 G87.
Old 01-28-2006, 04:21 PM   #8
desertlobo
Re: The unknown
I'll have to look tomorrow and let you know, its a 327 so I assuming its a small block. Will there be anything stamped on the axel or inside the pumkin.
Old 01-28-2006, 04:24 PM   #9
Flat 67
Junior Member
Flat 67's Avatar
Re: The unknown
Lobo, What are you going to be using for front disc brake?
Flat 67 is offline   Reply With Quote
Old 01-28-2006, 04:31 PM   #10
desertlobo
Re: The unknown
Right now I have no idea, like I said this is my first shot at something like this.
Have any suggestions?
Old 01-28-2006, 04:37 PM   #11
Flat 67
Junior Member
Flat 67's Avatar
Re: The unknown
Can you buy the front disc brakes from the same place/truck you are buying the rear end from?
Old 01-28-2006, 05:07 PM   #12
desertlobo
Re: The unknown
yea he has the front end too but I have already had the front end just rebuilt on the truck.
Here's a question, is there anywhere in the world I can get a list by chevy code of the options that my truck was built with? My glove compartment list rearend but it has a GM code and I was hoping it would discribe what the option really consists of.
Old 01-28-2006, 06:03 PM   #13
junkyardjohn
junkyardjohn's Avatar
Re: Need Help
WHY NOT JUST STICK WITH THE 3/4 TON REAR END?? YOU CAN GET A COMPLETE FRONTEND OUT OF A 71 OR 72 3/4 TON & HAVE YOUR DISCS. WHEN COMPRING A 3/4 TON REAREND WITH 375-1 GEAR RATIO AS COMPARED TO A 1/2 TON REAREND WITH 375-1 GEARS , THE DIFFERENCE IS PRACTICALLY NONEXISTANT. THE RIDE COMFORTABUILITY COMES FROM THE SPRINGS, & THE DRIVABUILITY COMES FROM THE GEAR RATIO. YOU MIGHT BE BETTER OFF KEEPING THAT REAREND & CHANGING OUT THE GEAR RATIO FOR ONE THAT YOU NEED (OR WANT). JUST ANOTHER THOUGHT. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 01-28-2006, 06:19 PM   #14
desertlobo
Re: The unknown
Would the front end out of a 71 or 72 have 8 hole front end?
Old 01-28-2006, 06:22 PM   #15
junkyardjohn
Re: The unknown
YES ... A 3/4 TON WOULD. IS YOUR MAIN OBJECTIVE TO DO AWAY WITH THE 8 LUG RIMS FOR SOME REASON?? JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 01-28-2006, 06:30 PM   #16
desertlobo
Re: The unknown
It was if I were to put a kit for the front disc brakes. Also I would like to pick up more speed and less torque. I have good 8 lug rims.
Old 01-28-2006, 06:58 PM   #17
junkyardjohn
Re: The unknown
YOU CAN PICK UP A COMPLETE FRONT END OUT OF A TRUCK UP TO ABOUT 1985 FOR ABOUT $100 -$150 & THEY ARE PRACTICALLY A BOLT IN DEAL. I THINK WHAT YOU ARE LOOKING FOR IS A CHANGE IN GEAR RATIO. I'M NOT TRYING TO TALK YOU INTO ANYTHING, BUT IF YOU WERE TO BUY A 1/2 TON REAR END WITH THE SAME GEAR RATIO AS YOU HAVE NOW, THE DIFFERENCE IN SPEED, TORQUE,& GAS MILEIAGE WOULD BE UNMEASURABLE. JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 01-28-2006, 07:03 PM   #18
desertlobo
Re: The unknown
I really appreciate the advise and I'm going to take it.
Thanks again
Old 01-28-2006, 07:15 PM   #19
junkyardjohn
Re: The unknown
Thanks again
NO PROBLEM.. P.M. ME IF YOU LIKE & I WILL GIVE YOU MY PHONE # (IT'S HARD TO EXPLAIN SOME OF THIS STUFF OVER THE COMPUTER) & I'VE BEEN DOING THESE FOR A WHILE NOW. JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 01-28-2006, 08:13 PM   #20
Mongo
YES_____NO
Mongo's Avatar
Re: The unknown
to do a brake swap you do not need to get the whole cross member! just get the upper and lower a-arms with spindles attached and the proportioning valve. Oh you may need to get the outer tie-rod ends for the newer spindles. everything will bolt right up.
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown
Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984
Help support the board
Mongo is offline   Reply With Quote
Old 01-29-2006, 02:25 AM   #21
junkyardjohn
Re: The unknown
YEP... YOU CAN DO IT THAT WAY. IT'S ABOUT 3 TIMES AS MUCH WORK... BUT YOU CAN DO IT THAT WAY . I'VE DONE IT BOTH WAYS, & FOR ME THE WHOLE CROSSMEMBER SWAP IS MUCH EASIER & FASTER. BUT WHATEVER WORKS FOR YOU. JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 01-31-2006, 04:43 AM   #22
53burb
53burb's Avatar
Re: The unknown
PM sent
53burb is offline   Reply With Quote
