J.B. Weld Filler
Anyone ever use this stuff. It's great and hardens like steel. I thought that I would try filling the holes where the upper trim mouldings go. I didn't want to weld the holes, as I'm not that good a welder. After I put 2 coats of this in the holes, I tried knocking them out with a punch. Didn't even crack. Only thing I don't like, is the setup time is long. Can take 12 to 24 hours to cure. Now, lets see if this stuff holds up over the years.......
1997 GMC Sierra Ext 1965 Mustang Last edited by 70GMCer; 01-28-2006 at 04:53 PM. |
Re: J.B. Weld Filler
probly work as well or better than the fibreglass bondo I used. ( I know, I'm a hack ) but my truck ain't no show queen. Be intresting to see you your holds up.
I got a bench seat baby, you don't have to sit over there. |
#3 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
![]() Quote:
I think they have a fast formula now. check www.jbweld.com if that is their address.
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() |
All I know is that this stuff seems too work. Like I said, I tried to bang out the hole I filled, and it didn't even crack.......
1997 GMC Sierra Ext 1965 Mustang |
Old Skool Club
![]() Join Date: Jun 2001
I had a pin hole in the top of the tank on my radiator. I used a brass bristle brush to clean it, then used some acetone to remove the paint from the area to be fixed. I mixed up some JBWeld and daubed it on. Since the tank was still warm, the product flowed really nicely and got thin. The radiator never leaked again, from that spot.
JBWeld is good stuff.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
'71 chevy s.bed/s.side
![]() Join Date: Mar 2005
I've used it for years. I patched a gas tank years ago with it and it worked great. I keep it around the house and use it for everything. If you plan on using it in place of body filler, watch out for pin holes, it tends to have more than body filler. It is some good stuff! Be sure to clean the surfaces very good with emory cloth or sandpaper. Have never tried the quick setting mix.
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
Kevin 1967 C-10 swb fleetside 1968 C-10 stepside 1999 Z71- sons dd 1999 2wd silverado-my dd 2003 Tahoe- wifes dd |
Designated A-hole!
I've patched a leak on a tank in a chemical plant with JB Weld.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
it's great stuff, you can drill and tap, it works for every thing else that other similar products wont i guess time will tell but it's never let me down
common sense isn't so common anymore |
it will definitely save a lot of time welding small holes up on the body.
I tried it on the AC control lever that broke. It lasted about 6 months and then cracked again. I also used it on my sons '65 impala rear panel, It was pot metal and the studs broke so I tapped new holes ran all thread in with JB so I dont think it will go anywhere.
So under stress I don't know how it would keep but for flat seals or somewhere where the metal is doing most of the work it will last.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
#13 |
i have had great success with it. prefer it much more over bondo as far as thickness, hardness, and the fact that its cheaper.
#14 |
![]() Join Date: Aug 2001
POR 15 makes a POR Epoxy Putty that works real nice also. The longer the cure the stronger the epoxy.
#15 |
senior member
we used the jb weld Kwik on a little 4 cyl forklift engine that had some scores in it then honed it out and the engine is still running fine
69 GMC bagged |
#16 |
![]() Join Date: Dec 2002
reapaired a fine crack about 1 1/2" long on the water side of a marine manifold ( 4 cyl Chev marine engine ) Cut a V shaped groove over and just beyond the crack. Filled with JB weld and slightly overfilled to a rounded shape. Did this over 10 years ago and not a leak ever !!! Have used The JB for other repairs and am sold on this product. Have repaired cracked levers by placing a small finishing nail on each side of the lever at right angles to the crack. This re-inforcment seems to take the strain away from the JB weld joint and adds stength to the repair.
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
#17 |
![]() Join Date: Jul 2005
I uesed this lots of times. First time was on a cylinder head eleven years ago. Still holding today. Is on a farmall tractor.
#18 |
F.A.S.T. president
![]() Join Date: Sep 2003
I have used it on dozens of engines to put screen kits and vent tubes in the lifter valley and never seen it fail. Also to repair salt water pitting on alluminum engine parts
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" |
#19 |
Thats the Hillbilly way
I've only tried it once on the plastic gas tank on my power washer it held for about a week then started leaking again .
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
#20 |
Jamie Hyneman is my twin
![]() Join Date: Nov 2005
You all have inspired me. I'm not that good of a welder yet, and have mirror mount holes to take care of.
dwaite72lnghrn, I doubt the JB weld didn't hold on the heater controls, more likely the control broke again next to the JB weld. Once pot metal corrodes, it is worthless.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
#21 |
dwaite72lnghrn--I have been successful repairing pot metal heater controls and other type levers with JB Weld. Like I stated in previous message; lay a small finishing nail on each side of the crack. Apply a thin coat of JB to the lever, lay the reinforcing nail lengthwise along the lever and applying another coat covering the nail. I have also cut a piece of light metal the width of the lever (or a little less) on each side of the break, applied JB and let set up. .......Jim
#22 |
Where have I been, not knowing about this stuff years ago.......Looks like I will be glad I used it to fill the holes........
#23 |
Nice I wish I saw this earlier!
I'll try it out tonight..... Here is what I posted.... http://67-72chevytrucks.com/vboard/s...d.php?t=186648
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
#24 |
Mine are very close to the same
Old mirrors suck...lol I'll get a pic...
#25 |
I filled in the 1/8" holes on the top of the door where the word "Custom" was. What I did, was on the back side of the hole, I placed a piece of masking tape over the hole. Then I mixed up the J.B. Weld and applied it to the holes. Be aware that you will most likely have to put 2 coats on. Also, do be in a hurry for this stuff to dry. Hope this helps.......
