67 chevy 1-ton front disc brakes ?
Have any of you boys and girls. (I assume there are girls on here too) put disk brakes of some sort on the front a 67 one-ton. If so how was it done.
Thanks archie =) =) =)
72 C-10 LWB, auto, factory buckets, leaf springs (driver) 72 K-20 project, 4 speed manual (need bed and cab) have 500 cad to go in it. 74 Jeep Wrangler (401 AMC , T18 4 speed) 2001 jeep cherokee bone stock John Deere 40W (pile) |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: 67 chevy 1-ton front disc brakes ?
I converted my 68 chassis (same as yours) to discs using a complete front crossmember swap from a 72 model dually. You can use any donor from 71 up through 87 though.
So the crossmember bolts in?? (i am not at home)
archie =) =)=)
Shanes Chevys used the front suspension from an 89 dually on is 69 one ton. It has the hydostatic breaks and it stops really well.
its all about the +6 inches
71/72 will pretty much be a direct bolt in... maybe some mods to run the brake lines... later cross members are almost a bolt in... I think there's a couple holes that need egged out a little.
Something to keep in mine, on the 67 - 70, the wheel studs were 1/2 inch, in 71 they went to 9/16, so you'll need a couple wheels, which moving to 16 inch rims will save you money next time you need tires too. |
Thanks guys
so I guess if i want to run 3.73 gears in the rear and disc brakes on the front I need to be looking for a 74 and up donor truck.... Happy Hunting archie =) =) =)
