Old 01-29-2006, 01:30 AM   #1
Ole Blue 68
Ole Blue 68's Avatar
Harmonic Balancer ?
Can you use the harmonic balancer off a 283 on a 350? Summit just says small block for its balancers? I'd much rather not spend the money for a new one.
Ole Blue 68 is offline   Reply With Quote
Old 01-29-2006, 05:12 AM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: Harmonic Balancer ?
You can but the timing marks were moved in 69, so you would have to compensate. The rubber in balancers ages, loses it elasticity and can slip. You will be far better off in the long run with a new one.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 01-30-2006, 12:13 AM   #3
Ole Blue 68
Thanks Fred T, I bought a new one and installed it today.
Now here's a kick in the ass. When I bought this truck back in the summer, the po told me the engine was a 283. With the intake it looked like one to me so I had no reason to think otherwise. We pulled the engine yesterday to swap in a 350 and just for the hell of it, I ran the casting numbers through Mortec.com last night. Turns out the damn thing was a 350 all along!
Just goes to show that you can't take anything for granted.
Old 01-30-2006, 02:24 AM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Was the casting number 3970010 cause gm made a 302 and a 327 with that same number. The 327 had an intake like the 283 with the oil filler in the front of the intake and the t-stat housing pointed straight ahead.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-30-2006, 10:35 AM   #5
Ole Blue 68
Nope it's 3970014 which only comes up as a 350 in all the online searches I've done. The intake is probably what threw me off though.
Old 01-30-2006, 12:46 PM   #6
kaycee
kaycee's Avatar
What size of balancer was on it?The 350 had a 8" and the 283/327 had 6 1/4" or 6 3/4" bal.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 01-30-2006, 02:37 PM   #7
Ole Blue 68
It was an 8".
