01-29-2006, 03:49 AM | #1 |
Please help...
just got a new clutch at aamco 2 weeks ago....tonight my one month old hurst 3 speed shifter started acting up, when i would accelerate then let off to decelerate i would hear horrific grinding from the transmission...later on tonight, on the highway, raced my friends 72 stang...im in third and trying to let it out and into second to go again and i cant even move the shifter...its like it locked up on me, stiff as a brick....i can unbolt the shifter plates from the tanny and move the shifter, but it wont come out of third gear???WHY???? so i fu**ed my clutch trying to get it to roll up the highway and running all red lights and stops signs on the way home... Can anyone please please please tell me if this is a tranny problem or a shifter problem which i doubt because i can move the shifter when not connected to the transmission...if it is a tranny problem, wtf is wrong with it, new clutch new shifter, and aamco said everything else was fine when they went to put the new clutch in...sooo its up to yall to tell me where to go from here...thanks - Mark Taylor-
1970 Chevy C/10 |
01-29-2006, 09:51 AM | #2 |
Re: Please help...
check the adjustment of the clutch it could be out of a justment get someone under the truck to watch as you press the clutch in and make sure it is releasing all the way if it is then you probley got a trans problem if its stuck in 3rd sounds like a shinco went bad i had one go bad in my 3 speed expect it got stuck in frist everyone wanted 800 buxs to fix it so i said forget it i founda used one for 75 buxs and lots of people have them laying around so find someone near you that got a 3 speed tranny get it from them install it and see what happend just my $.02
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 01-29-2006 at 09:52 AM. |
01-29-2006, 01:38 PM | #3 |
Re: Please help...
(QUOTE)when i would accelerate then let off to decelerate i would hear horrific grinding from the transmission...later on tonight, on the highway, raced my friends 72 stang...im in third and trying to let it out and into second to go again and i cant even move the shifter...its like it locked up on me (QUOTE)
SOUNDS A LITTLE LIKE THE NUT THAT HOLDS THE STEERING WHEEL IS DEFECTIVE. I LEARNED OVER 30 YEARS AGO "THAT IF YOU THRASH IT ....... IT WILL BREAK" IT APPEARS TO BE A TOSSUP OF WHAT WILL LAST LONGER... YOUR DRIVERS LICENCE.. OR YOUR TRUCK. IF YOU ARE GOING TO CONTINUE TO ABUSE YOUR 35 YEAR OLD TRUCK YOU BETTER EITHER LEARN TO WORK ON IT YOURSELF, OR HAVE TONS OF MONEY TO PAY AAMCO & A WHOLE BUNCH OF OTHER PEOPLE TO DO IT FOR YOU. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 01-29-2006 at 01:59 PM. |
01-29-2006, 03:07 PM | #4 |
Re: Please help...
What would the nut that holds the steering collumn in place have anything to do with my trnasmission john-....AND to the second reply, I was able to fully engage and dissengage my clutch fully, i just cant shift the gears, its stuck in third like i said before....thanks for the help and keep it coming
1970 Chevy C/10 |
01-29-2006, 03:09 PM | #5 |
Re: Please help...
What is a shinco, how does it work??
1970 Chevy C/10 |
01-29-2006, 03:18 PM | #6 |
Re: Please help...
Have you checked the lube in the trans? I used to manage a trans shop and periodically an employee would fail to top off after a clutch job and we would end up buying a trans. Happened once on an Audi fwd,that hurt.
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
01-29-2006, 03:18 PM | #7 | |
Re: Please help...
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
01-29-2006, 03:37 PM | #8 | |
Crew Cut
Re: Please help...
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN D A LOT MORE JUNK |
01-29-2006, 07:31 PM | #9 | |
Re: Please help...
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 01-30-2006 at 02:24 AM. |
01-29-2006, 07:35 PM | #10 |
Re: Please help...
by the wya i ment to say the synco in been bad they help keep the trans from grinding when you shift gears i had the one on my friut gear go bad and lock the trans in frist
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
01-29-2006, 09:29 PM | #11 | |
Re: Please help...
01-29-2006, 09:50 PM | #12 | |
Outlandish Trends - FL
Re: Please help...
-Bret 67 short-fleet sold! |
01-29-2006, 09:58 PM | #13 |
Re: Please help...
hey junkyardjohn......what in the world would make you want to come to somerset, ky?
01-29-2006, 10:10 PM | #14 | |
Re: Please help...
01-30-2006, 02:11 AM | #15 |
Re: Please help...
it has been converted to the floor...would not topping off my tans fluid after a new clutch job really cause this...if so, do i just need to top it off and it should be back to normall, or are things perm. f'ed up because i did not do this....i was given no instruction from the trans shop- ill keep in mind where i take my vehicles after this incident.
1970 Chevy C/10 |
01-30-2006, 02:28 AM | #16 |
Re: Please help...
go out and check it if it is low take it back to the trans shop and tell them they owe you a transmission one its stuck in a gearbecause your shifter linkage is out of adjustment then it or the synchronizer went bad which would cause the grining sounds btw this is my last post on this topic because above people can't be nice and i not going to get into a battle of wits and being smart because i not going to get baned. gl speed and hopes all get fixed quicky
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 01-30-2006 at 02:30 AM. |
01-30-2006, 08:02 AM | #17 |
Re: Please help...
I`m enjoying this post for the wrong reason.I agree,If it ain`t the seencrows,it`s that big nut behind the steering wheel.Depending on your size,it`ll take 200 ft/lbs +or- to get out of the truck.
01-30-2006, 09:11 AM | #18 |
4 eyed fever
Re: Please help...
Very entertaining! Just what I needed at the end of a 12 hour night shift. Thanks to all the players!
Al
1971 GMC 2500 4x4 1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto. 4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!! Last edited by al's71gmc; 01-30-2006 at 09:12 AM. |
