Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 01-29-2006, 04:58 AM   #1
gregbr
Senoir Member
gregbr's Avatar
K10 front axle block??
Anybody got one of these front axle spacer blocks (drivers side). Pictured is a 83 K10 I found on E-bay. Our K10 appears to need this. Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 01-29-2006, 01:44 PM   #2
soleeagle
soleeagle's Avatar
Re: K10 front axle block??
I would think twice before putting any blocks in the front axle. That is very unsafe.
Chuck
'85 Chevy Silverado 4X4
'91 Chevy 4X4 Suburban
http://www.cardomain.com/memberpage/545941
soleeagle is offline   Reply With Quote
Old 01-29-2006, 03:01 PM   #3
74 shorty
I second that. That is why you don't see lift kits with front blocks only springs.
74 shorty is offline   Reply With Quote
Old 02-19-2006, 11:40 PM   #4
alf4444
alf4444's Avatar
if it is a zero rate that many fab shops are making now it is perfectly safe. It simply bolts into the leaf pack and provides the lift of an additional spring without effecting the spring rate
2011 CCSB GMC 2500HD DMAX
73 GMC 3/4 ton 4x4
96 Chevy 1500 STD Cab Shortbed Z71
Owner of WickedWolfRC.com
alf4444 is offline   Reply With Quote
Old 02-21-2006, 01:53 PM   #5
gregbr
Senoir Member
gregbr's Avatar
What do you mean by negative rate? This truck has 4" lift Rough country springs on the front and blocks on the rear. The problem is the truck is unlevel on the front. Nothing appears bent or missing. After alot of measuring, there is 1/2" difference between the springs (measuring to the ground) and another 1/2" at the frame. A 1" spacer on the driver side between the axle & spring would put it back level. Greg
