Old 01-29-2006, 09:28 PM   #1
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Factory Spare Tire Carrier Bolts
I'm putting a factory underbed spare tire carrier on my pickup. Unfortunately I'm missing the bolts. I think they are 1/2" diameter? Could somebody measure the lengths of both bolts for me?
Thank you in advance,
Wes
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 01-30-2006, 11:58 AM   #2
knsmodels
I make Models
knsmodels's Avatar
Re: Factory Spare Tire Carrier Bolts
I only have one side handy......not sure where the other one is off the top of my head.....about an 1/8 short of 10" is the length of the pivot side.....I would have to guess the other side would be about the same....hope this helps.
found the other side......8 5/8" but it is not a regular bolt....has a special square washer on it to lock it in so you can turn the retaining nut off......Paul
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 02-03-2006, 01:10 AM   #3
badpeanut
badpeanut's Avatar
UPDATE: Factory Spare Tire Carrier Bolts
My tire carrier is approximately 3'-6" long from bolt hole center to bolt hole center. It seems to be too long since the wing nut bolt doesn't line up? A little background--the truck is a '70 GMC 1/2-ton and the tire carrier is from a '62 Chevy 3/4-ton.
Any help is appreciated,
Wes
'70 GMC LWB trailer
